GT!4
black dash replacement
GT!4
  • Can anyone tell me how to find the guy that sells the black dash parts for a GT14?                                   Thanks for your help
JC 1965
His name is Glen Pettit. You can find him in the vendors list.
GT!4
Thanks
MikesRJ
May I ask what is wrong with your dash? And if possible could you post a picture of the one you have, if you have one.
Edited by MikesRJ
GT!4
The upper dash has a burn spot about the size of a quarter and a corner broke off. The lower dash has a bow in. Both look dirty and worn even after a I cleaned them several times. I don't know much about sending photos on the internet. I will have to get my daughter to help me with that. Do you restore or sell the 2 dash panels for a GT14?
Thanks for your reply,
MikesRJ
I restore the panels for my restorations and have done a few for members of RS, and have written a rather easy to follow procedure for doing them yourself. Article and examples below. Even if you found an old nasty, but unbroken one, you could get them to look like the examples below by following the process in the article. :)
ARTICLE
http://www.mywheelhorse.com/modules.php?name=docs2&do=show_doc&id=1
LATEST DASH RESTORATION EXAMPLE
dash.thumb.jpg.778ac706e2208e702b4a4ae10
J8.thumb.jpg.8f916b51a0f3eb0c507927425fc
Edited by MikesRJ
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
