seven
I cut er rite in half
seven
hyd cylinder  was leaking so I cut in half went to hyd place put in new seals  welded it back together good to go
  • Like 4
Aldon
Got a pic of cylinder post repair?:wwp:
953 nut
:WRS:   Cool idea, glad you shared it with us.
CasualObserver
:text-worthless:
Frankly your story could use a little more plot development. :ychain:
Seriously though, Can you elaborate on the process?
What did you use to cut the cylinder?
How did you hold it while cutting?
Where in the cylinder did you cut? (Does it make a difference where you cut?)
How did you weld it back together without blowing a hole through it? (that cylinder wall can't be very thick)
How long did this repair take?
Any ballpark of what this repair costs?
Oh, and I see you're in Hastings.... when is the Little Log House show? Have I missed it this year?
Have you been or will you be coming to LeSueur?
JC 1965
Hello and  :WRS:       Sounds very interesting but :wwp:      :)
bmsgaffer
Just wanted to check... You made sure there wasn't a snap ring on the rod end before cuttin 'er in half, right? :teasing-poke::eusa-doh:
torch.thumb.gif.5c756ad9f283549b377482a0
:laughing-rofl:
KC9KAS
:text-worthless:
:ychain:
Inquiring minds want to know!
:WRS:
I have heard of this being done with our WH cylinders.....Cut them on a lathe.
WHX??
I think yer pulling our stump....never heard of that being done before. I woulda thought would have been easier to go to TS and get a new one.
bmsgaffer
I have seen someone else on here repair a cylinder by cutting it apart (not necessarily in half... but like one end off) and re-welding it...
Does TS has the right size cylinder for our application? Havent found many small replacement cylinders.
seven
YA I JUST CUT IT WITH A BAND SAW AT ONE ENDAWAY FROM THE RAM SEAL MY CUS WELDED IT TOGETHER HE SAID HE KEPT COOLING IT AS WELDING,THE METAL IS THICK PROBABLY 3/16 TIF NOT 1/4 THICK
