tommyg
Repowering a D
bmsgaffer
I suppose my biggest disappointment is that the tractor isn't original any more. I tried hard to replace parts with parts that were designed for it. But after 40 years, you just have to make some decisions. I was at the local county fair this weekend and they had a couple Wheelhorse tractors on display. I thought, mine could have easily been a candidate and would have really shined in that display. But with a non original engine, I'm not sure it is any more. I suppose a lot of us need to make decisions on replacing parts like knees and hips at some point. Still doesn't change who we are though, I guess.
I think you have a great candidate for shows! You not only have an old D in great shape but you also have one of the cleanest and most functional "D" repowers I've ever seen. It looks good, its wheel horse tough and it has modern power with easy-to-find and cheap replacement parts. I think that's a winner!
And I like the look of the V-twin from the sides! :confusion-shrug:
Thanks for the details and thorough write up! Edited by bmsgaffer
  • Like 3
mikekot3
You did a great job and thanks for sharing your project with us all !!
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
