emmettlodge
Price Check: 518H with Kwik-Way
emmettlodge
Just wanted to get a price check from the experts here.
This came up for sale next to me, it's a 518H with the Kwik-Way Loader.
The machine is in good condition. Hoses look good, welds on loader look good, bucket is straight.
Seller wants $2500, but he is known to negotiate (bought from him before) so it could be gotten for less.
Also are those the right sized front tires for this model?
Thoughts?
IMG_20150719_142246083_HDR_zpsaqk2t9i2.j
IMG_20150719_142259450_HDR_zpsnezlhqz4.j
IMG_20150719_142321516_HDR_zps59avmsyg.j
IMG_20150719_142332865_HDR_zpszgis0gh8.j
Edited by emmettlodge
AMC RULES
Around these parts...    :confusion-shrug:
not unusual to see the FEL alone list for $1500.
           :WRS:
Edited by AMC RULES
squonk
Price is right. Only problem I have with these loaders is that the bucket is way too big for the tractor's capacity. This is just my opinion. I would hate to see someone either get hurt or damage their tractor with that thing chuck full of stone or dirt. Let us know how that seat feels. I almost bought one of those. It felt comfy. :)
Edited by squonk
emmettlodge
I assume putting on wider front tires and duals on the rear helps a lot with this?
AMC RULES
Though originally intended for light duty materials(like mulch)...
within reason, they will still pick a healthy load.
IMG_3119.thumb.JPG.336fc05e4130f3d3b5571IMG_3120.thumb.JPG.6541f8bb67d0ab78ef858
emmettlodge
Thanks for the pictures.
What is the safe load lift max? 300 lbs?
bmsgaffer
Is anyone concerned about that unit having the Eaton 700 light duty transmission? Im surprised its still moving.
Definitely not made for loader duty, but maybe its been replaced with the eaton 1100? Check to see if it has a hydro filter on the back for the transmission...
  • Like 4
emmettlodge
there was no ffilter.
Might be better to buy this, transfer the loader to a 520, and sell the 518?
jackhammer
hmmm
Check it out guys... the secret entrance to that hidden cave   :handgestures-thumbupright:
Rick
Edited by jackhammer
squonk
I may be mistaken, That ARK loader on Craig"s tractor doesn't seem to "Hang Out" in front as much as the Kwik-Way. Maybe it's an optical illusion The bucket on my PK sits out quite a ways and I can really feel it when it's full of wet snow.
IMG_0249.thumb.jpg.6d803f20d256430cf92c5
Edited by squonk
953 nut
The fact that it is nearby adds value, my GT-14 with FEL was 700 miles away when I bought it.
shallowwatersailor
I'm not surprised that it is still moving! The Eaton 700 is stronger than you think. It's not a Tuff Torq K46. Wheel Horse marketed as being able to do ground engaging work - and it can.
roadapples
I have a 74 c160 with ark loader & 520 front end & gear reduction steering. It would take a lot more than $2500 to haul it away. They are too handy and too hard to find.
roadapples
By the way, don`t wait too long. We can see the phone # in that first picture, lol!
emmettlodge
Well probably ggoing to pass on this one, so its all yours!
cheesegrader
I think the price is fair.
I would also rather have it on a 520 for the gear reduction steering and eaton 1100.
Wider front tires will make it easier to handle.  Those are not stock, but would be good for snowblower duty.
That bucket is meant for snow, with the top deflector.  The angle iron across the top and the two eye bolts are add-ons.  Nice if you want to chain something up for lifting.
Maximum load is 500 lbs.  When I carry that much in my kwik-way/520, it really becomes a chore to steer.
Even with counter-weight, I wouldn't try to work with any more.
Forest Road
All in all it looks good. $2500 is a good price just for a loaded around these parts. I'd prefer it mounted on a 520 or an 8 speed vs the 518. But the tractor could easily be sold. Mine is on a 522xi. I couldn't imagine NOT having power steering! Sent from my iPhone using Tapatalk
slammer302
I've always wondered how hard the steering would be on a FEL horse i know the 520 with gear reduction steering would help but i see alot of older horses with loaders on them. My commando 8 is kinda hard to steer with just a snow plow on it
  • Similar Content
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • Workin_Horses
      By Workin_Horses
      Kwikway loader that is currently on my 520H (Tractor not for Sale) with custom quick attach for switching between bucket and custom made pallet forks. The sub-frame allows it to fit some other models as well.
      I designed and built the pallet forks and quick attach setup several years ago.  Just remove 1 pin on each side to switch implements.
      Forks are adjustable and removable.  2" box receiver built into fork rack
      Also included is a custom rear axle suitcase weight bracket that holds up to 6 of the 43lb weights
      You can bring a tractor and we can install it on your tractor here or bring a trailer and I can load onto a trailer for you.
      Pictured TRACTOR and WEIGHTS NOT for Sale.
    • The Tuul Crib
      By The Tuul Crib
      Here's another one I'm saving from turning into a toaster  or a microwave oven.The guy said if I didn't get this by this weekend he would scrap it! Mostly good for parts .  Believe it or not it has 800 hours on it. Hopefully the motor and trans are not toast!
    • SSman
      By SSman
      I just got home from looking at a one owner 1989 518h with 412 hours on it. The guy says it always only cut grass,nothing else. It's been sitting inside for about 5 years now. He said the fuel pump was giving him trouble,so it sat and he bought a new zero turn. Four tires are flat,it's missing the steering wheel center cap and one plastic headlight bezel. The machine itself looks actually really good and should clean up nice! The engine looks very clean,the cylinders were bright aluminum colored. The rear end was pretty wet on the outside but the dipstick showed full and very clean as well as the motor oil.
      Can anyone tell me any good/bad sides to this tractor? I know it's not even CLOSE to the 520. I know most of the notable differences. He wants $300 firm,and says if not it can stay put,doesn't bother him a bit. Is this a good price? I have  feeling i'll be doing a LOT more to it than a fuel pump just to get it going. Any input is appreciated guys,thanks!
    • Rollerman
      By Rollerman
      Doing some yard cleanup today & put my 310-8 loader tractor to use.
      My wife got the shot of me in the dog pen with the corny smile....notice the hat?
      I had a pretty decent load of lime stone rocks in the bucket & wanted to see how bad the steering would be....not bad.
      Once I upgrade the front tires & add the gear reduction steering I got from Kelly it should be really nice.
      I picked up the Kwik-Way at Steve Myers Service in OH, friend & member Nick857 let me know about it.
      The weight box came from another friend & member, Derek Workman.
      The 310-8 was one I gave my dad years ago to mow & plow snow with.
      He's not able to do the work anymore so I brought it home last summer.
      It's all dialed in now...well except the front tires & eventually the easy steer.
      Should be real handy with snow removal, mulch, river stone & whatever else needs done.
      Maybe build a set of forks for it next spring too?
