Similar Content
By Joe Reese
518H Project/Roller Cash - As Is Has last compression/spark last i checked, currently not running. Gauges work when hooked up to battery and engine turns over freely, Has new fuel pump & carb. Comes with original carb & parts
By RJ Hamner
Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
Ideas?
By Workin_Horses
Kwikway loader that is currently on my 520H (Tractor not for Sale) with custom quick attach for switching between bucket and custom made pallet forks. The sub-frame allows it to fit some other models as well.
I designed and built the pallet forks and quick attach setup several years ago. Just remove 1 pin on each side to switch implements.
Forks are adjustable and removable. 2" box receiver built into fork rack
Also included is a custom rear axle suitcase weight bracket that holds up to 6 of the 43lb weights
You can bring a tractor and we can install it on your tractor here or bring a trailer and I can load onto a trailer for you.
Pictured TRACTOR and WEIGHTS NOT for Sale.
By The Tuul Crib
Here's another one I'm saving from turning into a toaster or a microwave oven.The guy said if I didn't get this by this weekend he would scrap it! Mostly good for parts . Believe it or not it has 800 hours on it. Hopefully the motor and trans are not toast!
By SSman
I just got home from looking at a one owner 1989 518h with 412 hours on it. The guy says it always only cut grass,nothing else. It's been sitting inside for about 5 years now. He said the fuel pump was giving him trouble,so it sat and he bought a new zero turn. Four tires are flat,it's missing the steering wheel center cap and one plastic headlight bezel. The machine itself looks actually really good and should clean up nice! The engine looks very clean,the cylinders were bright aluminum colored. The rear end was pretty wet on the outside but the dipstick showed full and very clean as well as the motor oil.
Can anyone tell me any good/bad sides to this tractor? I know it's not even CLOSE to the 520. I know most of the notable differences. He wants $300 firm,and says if not it can stay put,doesn't bother him a bit. Is this a good price? I have feeling i'll be doing a LOT more to it than a fuel pump just to get it going. Any input is appreciated guys,thanks!
