chorusguy 227 #1 Posted July 16, 2015 This is a newer c160. My other two don't have this little black nipple on them. This thing sticks out pretty far and the inside of the rim nearly touches it. Feels like its made of plastic. Any information welcome. Thanks once again for your wisdom Share this post Link to post Share on other sites
pfrederi 17,926 #2 Posted July 16, 2015 Do you mean the dark colored cap on the end of the shaft coming out of the hydro motor?? Looks like a protective cap over the shaft the brake drum should be mounted on. Later model sundstrands added a real brake. The metal plate in the upper right with 2 holes in it looks like the mounting point for the brake bad that would have wrapped around the drum Share this post Link to post Share on other sites
