tophatbufflo 2 #1 Posted July 13, 2015 (edited) My 14 auto no name won't move I tried to adjust the friction clutch how the owners manual said but that didn't work.T tranny was full of fluid .What is the next step? TIA Edited July 13, 2015 by tophatbufflo spelling Share this post Link to post Share on other sites
bmsgaffer 2,045 #2 Posted July 13, 2015 Check that an axle isnt spinning within the hub. Might have broken a woodruff key in the axle. Also check that the hubs are flush with the ends of the axles.. same deal.Check your drive belt?Does it have hydro lift? if so , does the lift still work?Friction clutch is for the PTO, I'm pretty sure that wont help the drivetrain. Share this post Link to post Share on other sites
squonk 41,485 #3 Posted July 13, 2015 Tow valve not closed? 1 Share this post Link to post Share on other sites
tophatbufflo 2 #4 Posted July 13, 2015 The tow valve is closed I had to open it to move it from where I had it stored.No hydro lift.This is the friction clutch on the shifter that you adjust for forward and reverse Share this post Link to post Share on other sites
MikesRJ 552 #5 Posted July 13, 2015 http://www.mywheelhorse.com/graphics/file/Tractors/Tractor_1973_10-12-14-16Auto_OM_A-5325.pdf Share this post Link to post Share on other sites
tophatbufflo 2 #6 Posted July 15, 2015 I was wrong I had to use a pliers to open the tow valve and when I used the pliers to shut it I didn't get it tight en a screwdriver gave it another 1/8 of a turn and it would go forward and reverse. Thanks guys I just had to do the basics and check everything 2 Share this post Link to post Share on other sites
