Similar Content
By Tfarver
This is my commando I just picked up awhile ago. Looks like it was-tried to be a puller. Got it with no motor but have a strong 14 to install. Does anyone know how to preserve the sheet metal but keep the “rust look”. Will be using this unit for small farm chores. I really like the look currently with the rust and wear, kinda tells a story I suppose but I don’t want to leave the Tin “unprotected”. I’ve heard of guys lightly rubbing down the metal with used motor oil? Any thoughts, comments, concerns are highly appreciated!
By Rob R
I have a WH 310-8 Mower Deck, Tach-a-Matic 42” Toro Model 05-42MS-05, Triple Blade (1981-83). One of the Mandel's (outer) will NOT take grease at the Zerk fitting have removed the Zerk tapped on it made sure hole and opening good etc. but to NO avail any suggestions here. Thanks
By Ifixoldjunk
so the whole corner of my 42 rear discharge was completely rotten away. I’ve welded sheet metal before, but I don’t really know what gauge steel is need for a solid repair. I have 16 gauge on hand. Would something thicker be needed?
By Horse Newbie
So for the last 5 to 6 months I have been working on getting my 1994 520H up to operating condition after buying it from a friends backyard a few years ago...now that I'm 99 percent done with the tractor I want/ have to get the 48 inch SD deck that came with it up to operating condition also.
As you can see by the pics I have a lot of work to do/ full restoration...I have a few questions before I get started...
1. Do the two wheels on the back of the deck control the cutting height ?
2. Where/ who is a good source for parts ?...I would like to go back with as much new parts as possible, but some of the pricier parts I will probably be willing to use used if my budget forces me to ( spindle are my main concern here).
As you may be able to see from the pics, the front center of the deck has been knocked back quite a ways ( looks like PO centered a concrete driveway/ sidewalk edge, or one stout survey corner stob.
Any suggestions about straightening the front edge would be greatly appreciated.
Also if any of you would have the center front wheel bracket on a junk deck that you would be willing to cut off and sell to me, it would be greatly appreciated.
By Horse Newbie
As you can see by the pics I have a lot of work to do/ full restoration...I have a few questions be fore I get started...
