ziggyswheelhorse 1 #1 Posted June 28, 2015 Is there any reason the rear hubs on my raider 12 are pushed against the housing? Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
slammer302 2,155 #2 Posted June 28, 2015 the hub has more than likely worked its way loose Share this post Link to post Share on other sites
Brian01 481 #3 Posted June 28, 2015 There will be a square headed set bolt on the back side of the hub. Check it, if loose reset the hub n retighten. Share this post Link to post Share on other sites
ziggyswheelhorse 1 #4 Posted June 28, 2015 One was loose I just cleaned the axle shaft and it slid off and the other one was tight they where runnin on a 1/4 inch of the key so I slid both of them out till they where flush with the end of the axle Sent from my XT1080 using Tapatalk 1 Share this post Link to post Share on other sites
Ed Kennell 38,761 #5 Posted June 28, 2015 If my hubs only have one set screw, I always drill and tap the hub for the second set screw 90 degrees from the original. It will help prevent the hubs from working loose and wearing out the keyways in the axles and hubs.Oh, BTW, to Share this post Link to post Share on other sites
ziggyswheelhorse 1 #6 Posted June 28, 2015 Sounds like a good idea my 314-8 is like that I pull both of these I want everything to be right. Thanks Share this post Link to post Share on other sites
