ericampagna
GT14 Hydro Lift not working
ericampagna
I can not get the Hydro lift to work on my GT-14. I drained and replaced the Hydro Oil but no luck. I am pretty new to working on these so I'm not even sure where to begin trouble shooting. Thanks guys.
gwest_ca
Hopefully there is something in these that helps.
Here is a transmission service manual
http://www.wheelhorseforum.com/files/file/24-transmission-hydro-sundstrand-sm-492-4206pdf/
Lift valve and cylinder service manual
http://www.wheelhorseforum.com/files/file/45-lift-hydraulic-valve-and-cylinder-sm-810242r3pdf/
Garry
  • Similar Content
    • tractorboy79
      By tractorboy79
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Bear G
      By Bear G
      I was thinking about putting this brush guard on my ‘69 GT-14. So much for thinking.. I don’t really care for it..
      Original thought was it would look cool & help protect that exposed fuel tank.
      .  Pretty sure I’m going to abort on this project.
      Back to the drawing board..
        Yes, I know, wrong hood decals for ‘69..
      This hood is off a ‘70 I had.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
