Brian01
'68 Electro 12 Auto
Brian01
Well brought her home just under a week ago.
Brian01
Brian01
Here it is as of today....
Brian01
Working on painting engine tins and what not today.
Brian01
Just so the dull motor will match the rest of the freshened tractor...or that's the plan anywho
AMC RULES
Some really nice work...  :greetings-clappingyellow:
night & day difference.
Brian01
Thanks....
Brian01
Brian01
Had to drill one of the bolts out in the mesh that covers the shroud..broke off when I went to take it off...but drilled out okay and new bolt went in OK...thankfully
Brian01
Also had to tinker with the throttle...kept going back in to idle...its a little better now but not up to par...any ideas? Would be appreciated
Brian01
Painting gas tank and clamp...God only knows how long it'll take to dry....pouring down rain outside now...frekin humidity
gwest_ca
You can try to pinch the rivet tighter in the throttle control. The pivot has to be tight enough to overcome the governor spring tension plus the pull the governor develops when it is working.
I remove the rivet and replace it with about a 1-1/2" long bolt. Using a long bolt gives you about 1/4"-5/16" of bolt shaft that is not threaded and that is where the lever and bracket ride so they do not ride on bolt threads and wear. Shim as necessary with flat washers and add a Nyloc nut. Cut of the extra threads. Put it back together and you can reach in with 2 wrenches and adjust to the tension that is required to hold it with the engine running.
Garry
Edited by gwest_ca
Brian01
OK thanks....gas tank turned out like crap, I'll have to redo it, "one of these days"
Brian01
I did get fuel filter out on though....didn't have one at all before.
Brian01
Before....
Brian01
Brian01
gwest_ca
Is your serial number 469894?
Garry
Trouty56
You can get decals for the dash and where the direction indicator plate is....that is if you like.....
Brian01
Garry
Yes
Brian01
Yeah I know , just experimenting at the moment
Brian01
I liked the wire at first, now not even a day later I'm having second thoughts lol
Brian01
White not wire
Trouty56
White not wire
Let me take a pic of what the decals look like....
Trouty56
