cleat 6,728 #1 Posted June 24, 2015 (edited) This was my Fathers day present to myself. It has unknown hours on it but runs well and all idlers are nice and tight so I think hours may be low. Only thing to make me think otherwise is the steering wheel is polished smooth.I have not mounted the 48" deck yet because I had to order a belt for the bagger. Not shown in the pics is the plastic tube from the bagger blower to the bagger itself.Deck has some weld repair but seems real solid and all moving parts spin properly.Cleat Edited June 24, 2015 by cleat 6 Share this post Link to post Share on other sites
Wheel-N-It 2,969 #2 Posted June 24, 2015 Nice machine Cleat! That should be a good addition to your collection. Share this post Link to post Share on other sites
shallowwatersailor 3,213 #3 Posted June 24, 2015 (edited) That looks like a decent find! The "Father's Day Present-Giver" certainly knew what you wanted. Edited June 24, 2015 by shallowwatersailor Share this post Link to post Share on other sites
WHX?? 49,488 #4 Posted June 24, 2015 NICE....i'm lookin at the red 4x4 behind the mower tho Share this post Link to post Share on other sites
cleat 6,728 #5 Posted June 24, 2015 That is my Chinese tractor. Runs better than anything else I own. Has around 300 hours on it now and has only had routine oil changes.Rated at 25 HP but would drag all of my 520's at once easily. Different HP rating I guess.Cleat Share this post Link to post Share on other sites
JackC 617 #6 Posted June 24, 2015 Cleat, The 416-H is a nice machine and sounds almost as good as the 520H. I like multiple machines so I can spread the hours and each can have different attachments. That machine could be the dedicated bagger machine when you need it. Great machine for use in the fall or spring for leaf pick up. Share this post Link to post Share on other sites
cleat 6,728 #7 Posted June 25, 2015 All belts installed, deck and bagger hooked up. Mowed back yard.Works well, not perfect, it leaves a little bit of grass but not bad. 2 Share this post Link to post Share on other sites
PaulC 342 #8 Posted June 25, 2015 looking good Cleat!! your really starting to stack them up over there .I have 3 good running machines and ive found myself rotating them for mowing duty this summer. My brother helped me jockey some decks and blades around yesterday and asked what are we were playing musical decks or something Share this post Link to post Share on other sites
WHX?? 49,488 #9 Posted June 25, 2015 Make sure you run the right and extremely sharp blades. Some guys do say that fthe flater "recycler" blades worked better. Keep the chutes & blower wheel clean. From the pics its looks like you have the outboard belt in order. My neighbor had a bagger like that and it really picked up stuff nice. I mean every blade of grass. Your gonna love that for pickin up fall leaves...no more raking by hand! Share this post Link to post Share on other sites
cleat 6,728 #10 Posted June 26, 2015 I, for this test, just used the blades that came on it as is.everything is clean. The screen on the bagger looks to be only the bottom half but no grass was blowing out there.Belt on the fan drive is a 4L740.This entire deck right up to the mule drive has absolutely no guards or covers so I will be on the lookout for those except the mule drive, I have that one.Cleat Share this post Link to post Share on other sites
MalMac 1,332 #11 Posted June 26, 2015 Yep get those guards. Especially on the blower. I have used that same set up for years on leaf pick up and I can tell you the occasional stick you might get into in the leaves will get up into those belts. I have had that happen even with the guard on. If you don't keep debris out of there your asking for trouble. I have a dedicated 42 in deck that I use just for leaf pick up. I switched to gator blades and it really made a difference in the leaf pick up. After the first time I went to dump the bags they were way considerably heavier. I don't like the gator for grass cutting, but they sure do mulch the leaves up.almost double the amount that goes into the bag. Share this post Link to post Share on other sites
Zeke98 2 #12 Posted August 16, 2016 I'm a new owner of a Wheel Horse 416-H (1991). Can anyone suggest where I might find a bagger for this tractor? Thanks! Share this post Link to post Share on other sites
cleat 6,728 #13 Posted August 16, 2016 Well, check out this site from time to time, ebay (likely costly there), or kijiji or other classified sites. You can buy one new here: http://www.newhavenpower.com/Toro_Classic_vac_Bagger.html Cleat Share this post Link to post Share on other sites
Wishin4a416 2,191 #14 Posted August 16, 2016 Nice present Cleat!!! Cant beat that. When you have time, could you get a picture of the turbo and belt setup please? Share this post Link to post Share on other sites
cleat 6,728 #15 Posted August 16, 2016 I will get some pics up this weekend. Share this post Link to post Share on other sites
Zeke98 2 #16 Posted August 18, 2016 On 8/16/2016 at 2:14 PM, cleat said: Well, check out this site from time to time, ebay (likely costly there), or kijiji or other classified sites. You can buy one new here: http://www.newhavenpower.com/Toro_Classic_vac_Bagger.html Cleat Thank you! Share this post Link to post Share on other sites
cleat 6,728 #17 Posted August 19, 2016 Here is the belt drive. What you can't see is the belt going to the double pulley on the right hand deck spindle. Belt for the bagger goes on the upper pulley. Share this post Link to post Share on other sites
