1054 won't engage gears unless mow deck is engaged
By
Garland Farms, in Transmissions and transaxles
Similar Content
By Reeferred
Need help,. 244-h model 72041 newer. The drive belt keeps coming off is it to lose, to tight? Any ideas would be great
By slimkimg
I have a 1969 Commando 8 WH with a 36" RD mower deck. Model 5-2362.
My problem is that I believe there is a bad bearing somewhere causing the belt to slip and stop. This in turn is not letting the mower cut my grass.
I have a brand new belt 1/2 x 28 (manu specs). So, where might these bearings be that I could change them?
Thank you all in advance and hope I can change these and get back out there.
