Hydraulic Rotary Broom with extra hydraulic pump belt configuration
By
kiu, in Implements and Attachments
Similar Content
By gfullz
Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
By kurm
You can search for the specs but here are some links:
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en
https://lookup3.toro.com/partdex/modlinfo.cfm?xCaller=Toro&o=2&x=22004&b=9900001&e=9999999&m=73552&y=1999&n=523Dxi Garden Tractor&channel=CN
https://lookup3.toro.com/partdex/modlatch.cfm?xCaller=Toro&x=22004
This is a beast! Comes with the 60" deck and also a 48" deck and a new battery. New belt (installed but unused), newer hoses, regular maintenance.
There are wheel weights too but idk if they fit this unit as I've never tried.
758 hours
I got a zero turn and a Kubota tractor and this has sadly become ignored.
By Trouty56
Service manual #810242R3
12 pages 1.52MB
Dated 09/84
Also listed as manual 492-4208
Replaces manual #810242R1
whlifhyd.pdf @ Toro
A service manual for the hydraulic lift valves and cylinders.
Included is a description of the adapters needed to make hoses and where to get them.
1983 C-145 Automatic model 01-14KE04
1994 416-H model 73421 Serial 4900001-4999999
1997 416-H model 73423 Serial 7900001-7999999
By JasonMc
Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
Jason
By jmack
I'm needing the o-ring sizes for my control valve assembly to my D-180. Does anyone have a list of these or the McMaster Carr part numbers?
Thanks,
Jonathan
