robojoe9
Shifter removal on late model 8 speed
robojoe9
I've looked at parts breakdown and seems simple but do not want to mess anything up. How do I remove shifter from trans? Just loosen the set screw?
Please help me out, pictures are always nice, even diagram etc.
Thanks
MU
slammer302
yes just loosen the set screw
robojoe9
Thank you very much.
rmaynard
There should be a jamb nut holding the set screw from backing out. Loosen that first, then the set screw. Be sure the transmission is in neutral before beginning. It makes it easier to reinstall the shifter.
robojoe9
Again thank you for point on neutral.
MU
