martinarcher
76' B-100 Restoration
martinarcher
Thanks guys!  I have no clue how many hours are in it.  The most accurate estimate I could give is "a lot". :)  I tore it down in May which took a few good days.  I worked on it in the evenings from there on.  I had some things that got in the way and lost probably a month.  The engine rebuild took forever since the block was at the machine shop that wasn't in a hurry.  I got the block back in Aug and in the meantime that gave me time to finish the paint and body work.  I finished it in early Sept.  Like I said, I worked on it evenings and not solid.  Hope that helps a little.
Thanks for the heads up on the PTO pulley.  I can't believe I did that!  It was right and I took it apart a few times to fix the front wheels that have been on backwards for 20+ years.  I guess when i finally put it together for good I was a slot off!
