tmix 34 #1 Posted June 18, 2015 Just picked up a D200 In need of some pics to see mule drive hooked up. Is there a adjuster to keep mule drive belt tight to clutch? Any help would be great. Share this post Link to post Share on other sites
Trouty56 567 #2 Posted June 18, 2015 Should be on the left side of tractor on the mid attach point......The deck attach rod fits in the mid attach and the handle fits in a sliding mechanism that moves the deck forward and back to loosen or tighten the belt. There is a knob under the left footrest.... Share this post Link to post Share on other sites
tmix 34 #3 Posted June 18, 2015 It came with a blower hooked to it. now i want to put the deck on. That part and knob is a separate part? Share this post Link to post Share on other sites
Trouty56 567 #4 Posted June 18, 2015 Could be....Mine came with it on as it came with a deck.... Share this post Link to post Share on other sites
tmix 34 #5 Posted June 18, 2015 Thank you very much for your time. I'll have to do some looking tomorrow Share this post Link to post Share on other sites
Trouty56 567 #6 Posted June 18, 2015 Thank you very much for your time. I'll have to do some looking tomorrow I didn't have the energy to do a search last night.....check this thread out......http://www.wheelhorseforum.com/topic/33573-fitting-a-deck-on-a-d/#comment-292045 Share this post Link to post Share on other sites
tmix 34 #7 Posted June 19, 2015 found the part in the box of stuff but now having a hard time of putting the belt on, its a gates high power II B102, i seem to be short by an 1 1/2". Any help would be great. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #8 Posted June 19, 2015 (edited) 1973-74 Operator manualhttp://www.wheelhorseforum.com/files/file/356-mower-rotary-48in-sd-1973-1974-5-1220-om-iplpdf/1975 Operator manualhttp://www.wheelhorseforum.com/files/file/738-mower-rotary-48in-sd-1975-5-1221-om-ipl-803879pdf/1976 Operator manualhttp://www.wheelhorseforum.com/files/file/3272-mower-rotary-48in-sd-1976-65-48xs01-om-803450r2pdf/1978 Operator manualhttp://www.wheelhorseforum.com/files/file/970-mower-rotary-48in-sd-1978-85-48xs01-om-810013r1pdf/1979 Operator manualhttp://www.wheelhorseforum.com/files/file/502-mower-rotary-48in-sd-1979-95-48xs00-01-om-810013r1pdf/A search of the Files using the model numbers should bring up the parts lists.The original 102868 belt is still available from Toro and HA x 105.5" = 1/2" x 105-1/2" long.A Gates Industrial B102 is 5/8" x 105" long. On B belts add 3" to the part number to get the belt circumference.For Gates Industrial A belts which are 1/2" wide add 2" to the part number to get the belt circumference. (An A102 is 1/2" x 104" long)Gates replaces the original 102868 with A103 = 1/2" x 105"Garry Edited June 19, 2015 by gwest_ca Share this post Link to post Share on other sites
tmix 34 #9 Posted June 21, 2015 got the right belt now. WOW cuts great, The little womans in the back yard cutting with the Raider 12 and me in the front yard with the D200 LOL Now she's talking Horse race. Silly girl. Thanks for all the help GUYS 1 Share this post Link to post Share on other sites
