Duke's Horse
702 Steering Gear
Duke's Horse
New member, been watching for a long time.  Recently purchased a 702.  The little tractor is in great shape considering its age.  The tractor is going to be a project for me and the kids to work on and play with.  One problem that I have noticed so far is with the steering gear on the end of the steering shaft, part# 3917 bevel pinion.  There is a missing, broken tooth.  It is rotated such that it would rarely make contact, except for a full left turn.  I weld, so I initially though I would weld it up and grind it back into shape.  After pulling the gear off of the shaft, I noticed how thin the wall was and am concerned that welding on it may further weaken the gear.  Any advice.  Been looking for a replacement part for several hours with no luck.
Thanks!
20150605_131536[1]
squonk
If your talking about the little gear that is on the shaft that the steering wheel is on I have it.
DennisThornton
Thanks!
20150605_131536[1]
That 702 got an electric start?
Plus I've been known to do a little welding too.  What's making you nervous?
Dennis Thornton
  • Similar Content
    • Mike in NC
      By Mike in NC
      This happened to jump on my trailer. I am thinking it is a 702. 7 HP Kohler with 62 printed on the serial number sticker. It needs some parts and some work, but engine is loose. Can't beat free! Guy said it was his dads tractor and the last time he remembers it running, his dad drove it. He said his dad passed away 26 years ago. Now I have a 701 and 702!
    • ayeater
      By ayeater
      Hello, I am currently nearing completion of the restoration of my Wheel Horse 702 and I am finding parts that I am missing including a starter belt cover, brake guard, seat, deck height adjuster and possibly a new steering wheel. If anyone can point me in the direction to find them I would greatly appreciate it! Thank you!
    • mhlmeader
      By mhlmeader
      Hi folks, long story, but here goes.  My dad got this or at least part of this tractor about 30 years ago, I vaguely remember going with him and helping heft it into the back of a pickup truck.  He ended up blending two tractors together for some reason, I dont know why.  He's used it in his small garden, pulling trailers and such.
        Fast forward, he's 72 now, I'm turning 48 soon.  So, anywho, he tells me his tractor is locked up, wont shift!!! Rutt row!!! But it is at least in neutral.   I didn't have alot of time to mess with it, not that I wouldnt have, so he finds a place in south bend( an old wheelhorse dealership) that will work  on  it.  We load it up, get there, guys come out to look at it, and guy ask if that's a hydrostatic drive!!, oh no, I knew we were in the wrong place, turns out they wont mess with it, too old!  So before it escalates,  I tell my dad, I'll take care of it, I knows some people, dig it!!
        So, on the way home, I says, you have left that tractor outside alot haven't you? Oh no, son, always inside, I didn't believe him.
      So I do some googling, and reading through the forum 9n what to do first, or to try.  First, I drained the oil, but there wasn't any, so I shook the tractor and drained the quart of water outta the tranny.  Then I filled it up with gear oil, started the tractor, let it idle abit, slowly but shirly I could shift through all the gears!!!! Yippy!!!!
       Then I noticed the head gasket appeared to be blown,  was blowing out the side.  Got a new head gasket,  old one wasn't actually blown, but I installed new one anyway, still blowing by.  More googling led me back here to learn to sand the head as best I could, and then more, pluse some spray on copper permatex.  Sealed the gasket!!!! WOO HOO!!
        So next is attaching a fabricated belt restrain on the bottom of the belt guard, I learned I needed that from looking through the forum too, she grinds a little bit when trying to shift.  And I also ordered a new break band today from one of the forum members.
      I actually power washed it today, its seen better days, but starting to look better.  I'm gonna change the tranny fluid again, change the engine oil, and then I'm gonna call it good for now.
        Anyway, just wanted to share about my dad's old horse, and how I been spending my time lately.  Learned alot too!!!
    • CasualObserver
      By CasualObserver
      1962 Wheel Horse sales mini brochure. Original is only 1/4 size of regular paper sheet.
      Full size
      10 pages 1.8MB
    • Tyler71
      By Tyler71
      Hey guys I’m needing to figure out 100% what attach a matic I need to mount a mid mount grader blade to my 702 all I have found is I need a MA-1 speed hitch but what years do I look for or does anyone have pictures
