stevebo-(Moderator) 8,333 #1 Posted June 10, 2015 Are the wiring harnesses on the engines of a 520-8 the same as a 520H? I might want to do a drect swap. Share this post Link to post Share on other sites
nylyon-(Admin) 7,294 #2 Posted June 10, 2015 (edited) In the manuals section is the wiring diagram for the 520-8You can check for the 520-H as well and compare Edited June 10, 2015 by nylyon Share this post Link to post Share on other sites
TJ5208 1,824 #3 Posted January 30 On 6/9/2015 at 9:15 PM, stevebo said: Are the wiring harnesses on the engines of a 520-8 the same as a 520H? I might want to do a drect swap. How did it turn out what all had to be done? 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,333 #4 Posted February 12 Sorry I cannot remember yesterday lately let alone 9 years ago🤦♀️ 2 Share this post Link to post Share on other sites
cleat 6,100 #5 Posted February 13 I believe the harness is the same, just an unused wire or two that would go to warning light sensors. Even the 520HC engine I can plug into a 520H. I even plugged a 416 engine into a 520 with no issues. 1 Share this post Link to post Share on other sites
