dgjks6
37 inch deck question
dgjks6
so I just bought a 37 inch deck. The one I had before had the double v mule drive and six sided belt.  This one has a regular belt and mule drive. It looks like the two front pulleys on the deck were changed. They were both flat. We hooked up the deck and it worked. The guy said it came this way.  Did they change the set up?
dcrage
You should have one flat pulley and one V pulley on the mule drive.
TIMOTHY McCLELLAN
is it a 36 in belt on the 310-8 RD deck or 37 " ?
gwest_ca
Two models of 36" deck can be rear discharge or side discharge and have 3 blades.
37" is side discharge only and has 2 blades.
Garry
TIMOTHY McCLELLAN
THANK YOU FOR ALL THE GOOD INFORMATION !!!!!!!
