Sunstrand to Eaton Transaxle Swap ???
By
oliver2-44, in Transmissions and transaxles
Similar Content
By Thatoneguy
So I washed my rear end and sundstrand 90-1136 and now the by pass valves leaks when I screw it in past a certain point. If I screw it all the way in I can sit there and watch the fluid start seeping past it. I changed the o-ring with an R-04 i believe is what it was. Do these require some sort of thread sealer? There was nothing on it when I took it out, and when I used the valve to push the tractor in my shop it worked fine and has never leaked. Any ideas would be wonderful!
By TractorEd
I’ve decided to start this thread to keep this info together. It’s about this C-161 I have.
It showed up at my house one day around mid-2021 as a “parts” tractor.
I had no idea this was going to be left at my door, abandoned, tired, unwanted. I can’t remember a lot of what I was being told about it as I was staring at it wondering why I was chosen, apparently, as the one who was to strip it of it’s organs and transplant them into some other “being”.
By the time those who brought it left, even though I never said it until just now, I knew I was going to attempt to resuscitate her.
No longer an “it” she was certainly worthy of a shot at another life. 16 HP Kohler, Sunstrand Hydro and hydraulic lift! I had already fallen in love with the C-100 I grew up with that I later inherited, but this girl had something extra, something different about her that I thought was …
appealing.
Parts tractor? Not if I can $@%# help it!
She was glistening. Maybe it had something to do with the rain that day on the ride over. But she IS glistening!
By mattd860
I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
Here is a link where you can download the installation manual: CLICK HERE
I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
Thanks!
By olivertractor
I was pulling a roller and thatch rake the other day with my c120 hydro and noticed oil on the back of the fender. On looking closer I saw the plug thing on the back of the pump leaking oil. Any advice on how serious this will be to repair? Anything helps
By Maxwell-8
So yesterday I picked-up a C175. She was rusting away as she was stored outside. She had a new to her Kohler K341. @squonk The previous owner indeed better had"LET AN ELECTRICIAN CHECK his SHORTS!" as bad wiring shorted the battery out, and exploded/melted. She has a Sundstrand hydro pump with a Filter, is that normal? By the pump I believe it's a 1980. But you never now for sure as it's made in Oevel. Due to the bad wiring, the engine was in no running condition. But don't think the K341 has many hours on it. The hydro I don't know if it works. She was hard to push. So i lift up one wheel, so we could roll here one one wheel and the diff prevented the trans from locking up.
So first things to do:
1) get the engine running
2) replace the steering wheel, but don't think removing it will be very hard as it's already split in two.
3) replace the axleseals, the oil leak caused a lot of sandbuild up as she was mainly used on for leveling out a horse track.
4) clean all the acid and remove all the old wiring to do a full rewiring
5) replace the plastic seat pan with a metal.
6)...
I'm looking forward on my first C.
It's also my first hydro, I don't know a lot about them and prefer actual gears. Simpler and need less maintenance (parts-shortage).
But since I couldn't find another project WH and me hearing a lot of good things about hydro's on the forum.. I finally took the shot.
