ericampagna
This may be a really dumb question but I'm new to restoration. What is the best/safest way to clean the engine and internal components? I have a GT-14 that is covered in gunk and I'd love to get it cleaned off, maybe even repainted down the road if I can find the time.
Thanks.
953 nut
Since the GT-14 has no electronics you should be able to do a good job with a pressure washer, just stay away from the voltage regulator and cover the air intake and muffler with plastic to keep water from getting in. I wouldn't use any chemicals until you see what the washer will do.
ericampagna
Thanks. I will give that a try.
bds1984
I cleaned off my C165's frame last weekend using a pressure washer and it did a pretty good job.  For some really tough jobs, I used cheap liquid laundry soap fed through my pressure washer and it cleaned off anything I wanted it.  Just be sure to rinse thoroughly afterwards.
  • Similar Content
    • Bear G
      By Bear G
      I was thinking about putting this brush guard on my ‘69 GT-14. So much for thinking.. I don’t really care for it..
      Original thought was it would look cool & help protect that exposed fuel tank.
      .  Pretty sure I’m going to abort on this project.
      Back to the drawing board..
        Yes, I know, wrong hood decals for ‘69..
      This hood is off a ‘70 I had.
    • Bear G
      By Bear G
      Anyone have pics of the CORRECT steering wheel for a ‘71 GT-14?
      also, is it 14” or 15”?
    • Bear G
      By Bear G
      Looking for NICE Clean GT-14 steering wheel
      (3 spoke) like this one.
      could also use new dash plate.
      I like the ones Glen P. Has, but the raised white letters aren’t painted. Not sure how to go about doing that.
      Please text me if you have a steering wheel or clean dash plate for sale or know anyone that does.
      Thanks,
      Bear G
      419-681-4249
    • Bear G
      By Bear G
      Another GT-14 in the Herd.
      Not perfect, but it runs & drives.
      Doesn’t smoke.
      New carb & fuel pump. New tires.
      I have a super nice seat for it.
      We’ll see what becomes of this one.
    • Jonesy0418
