Bordeaux
Can You Help Determine Year And Estimated Value Of This Raider 12
Bordeaux
Can you help me determine the year and estimated value of another one of my husband's Wheel Horses?  (I couldn't have sold his GT-14 without you and so appreciate your help on that one.)
I found where the serial and model numbers are located on the tractor but they are not readable. The serial number is something like 010008301. Probably not too helpful.
I have attached some pictures. Not sure if it runs.  It has been stored a long time - as you can tell by the pictures.
Thanks!
Edited by CasualObserver
Edited title
Bordeaux
Forgot to mention I do have the blade/plow that I think attaches to it. Will post asap.
rmaynard
The 1970 Raider 12 was equipped with a Tecumseh engine and an 8 speed transmission as your is. All others had Kohler (according to the Wheel Horse Master Products List).
ID number would be 1-6253
Considering the fact that you don't know if it runs, plus it has been modified and is missing parts, as well as having a Tecumseh engine, I would not pay more than $100 to $150.00.  Accessories would add a little more to a package deal.
Tankman
Looks just like my '68 Raider 12. A classic, a project too. Good luck if you pick it up,
Edited by Tankman
rmaynard
I believe she is looking to sell it.
Bordeaux
Rmaynard and Tankman -
Thanks so much for taking the time to respond, and rmaynard, especially with all the details you gave me.
It is unbelievable how much you guys on this forum know about Wheel Horses.
Appreciate it!
  • Similar Content
    • AndyZ
      By AndyZ
      Operator manual #A-5274
      Wiring
      6 pages 7.31MB
      Illustrated parts list link
      Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
      For 1970 electric clutch use Electro 12 model 1-7255
      2 pages 282KB
      We also have the 1971 tractor parts manual that followed
      1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
      1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
    • mmmmmdonuts
      By mmmmmdonuts
      My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
      Thoughts?
    • ohiofarmer
      By ohiofarmer
      I am picking away at the k series on the raider10. Basically the Piston blew through at the ring grooves as it appears the rings may have had too large a gap. I can feel a slight erosion of the bore where the ring gaps All lined up, but not even close to catching a finger nail.
      I am hoping just hoping out the bore will get it back to round close enough that a ring job will do .
      In any case I can measure the bore and report back. Discipline demands that I do not tear this engine down right now as too many things are taking up my time.
      Just hoping the gurus can offer a bit of guidance
    • davidtmercer
      By davidtmercer
      Just recently had a 10 pinion differential axle gears lose their teeth as shown in this picture from a post in 2014.
      Was wondering if others have had this happen and if they determined the root cause and corrective actions.
      I am considering replacing the two axle gears and five pinions that were destroyed but did not want the same thing to happen again.
      I assume the failure was due to a worn cylindrical spring that I also plan to replace.
    • 12 hp Kohler
      By 12 hp Kohler
      Been looking at a lot or Raiders and Chargers lately and was wondering if they all have LSD? I know most of them did but I was wondering if some of the later models might have had the Uni drives instead ?
      Thanks, Robbie.
