edgro 677 #1 Posted May 30, 2015 I'm in the process of installing a Briggs 16hp twin from a GT1600 into my 414-8The Kohler needs a rebuild (future project), the Briggs came from a parted out tractor.The engine sits a little forward from where the Kohler was in the 414-8.The GT1600 calls for an 83" belt and it's too short.Just wondering if anyone has had this problem before, and what belt to use.Thanks for any adviceEd Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,133 #2 Posted May 31, 2015 The GT-1600 was an 8-speed also?Garry Share this post Link to post Share on other sites
edgro 677 #3 Posted May 31, 2015 Yes the GT1600 was an 8 speed Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,133 #4 Posted May 31, 2015 I don't know the dimensions of the original 107939 belt but it was replaced by 93-9809 which is HB x 83.5" which is 5/8" x 83-1/2" so 83" would be short for the original application also.Belt chartshttp://www.wheelhorseforum.com/files/file/1391-chart-belts-tractor-drive-1956-1999-15-pages-492-0392pdf/Garry Share this post Link to post Share on other sites
953 nut 56,148 #5 Posted May 31, 2015 Presuming the pulley size is the same I would just measure the difference in motor mount to crank shaft center line, multiply that by two and take the old belt to NAPA and tell them you want one that much longer. Share this post Link to post Share on other sites
edgro 677 #6 Posted June 6, 2015 The 83 1/2" belt from the Toro dealer seems to fit OKThe Tractor Supply 83" belt was too tight, and the 84" was too looseI also had to use the belt cover from the GT1600, as the Briggs engine sits a little tallerProject still in progress Share this post Link to post Share on other sites
edgro 677 #7 Posted June 14, 2015 Tractor is now out of the garage and running 4 Share this post Link to post Share on other sites
edgro 677 #8 Posted August 13, 2015 I am unable to make the PTO hoop work. The donor tractor with the B&S did not have one, and the one for the Kohler don't fit.anyone have a picture, or possibly the correct part for salethanks for any help or adviseED Share this post Link to post Share on other sites
Don1977 604 #9 Posted August 16, 2015 I looked on Parts Tree and any C 1x1 1978 or 1979 loops are the same. Share this post Link to post Share on other sites
edgro 677 #10 Posted August 17, 2015 there is something different at the top, there is an engine bracket that won't let the Kohler clutch hoop fit I will send a picthe parts lookup is calling for either 108825 or 106779I bought what was sold as a 106779, and it is the same as the Kohler hoop, so I am assuming I need a 108825I am going to do some more searching of parts listings to see if this fits any other tractors with the briggs 16hp twin. I think a c-161 has one, not sure of any others Share this post Link to post Share on other sites
MikesRJ 552 #11 Posted August 17, 2015 (edited) I keep two broken 130"+ V-belts hanging on the shop wall which I use for measuring belt sizes. One is a 1/2", the other is a 5/8", both ends of both belts have been cut square. Whichever is required, I thread the belt on the pulleys in question, making two measurements. One with belt tension, the other without. I mark the middle of these two lengths and measure from the end to this new mark. I round shorter to the nearest inch and you have your belt size. I.E. if you performed the steps previous, you used the 1/2" V-belt, and the measurement was 86"; go to TSC and get a 1/2" x 86" belt.Hope this helps. Edited August 17, 2015 by MikesRJ 1 Share this post Link to post Share on other sites
