Followers
0
wheel Horse c120 wiring harness NEW IN SEALED PACKAGE
By
Cttopcop, in Wheel Horse Electrical
Similar Content
By firemanironman
I picked up a wheel horse and I am having trouble finding the connection for this wire. I have no spark and have searched for the placement of this wire within the distance of its length...any ideas?...can't seem to paste the picture....
By Chuck14025
C120, 1974/75
I added braces and shims to the rear end of the frame to beef up the cracked existing 'frame to transmission bracket'. Now, the parking brake does not engage.
The shims are about 1/8" and have to stay on.
Is there a way to adjust the parking brake?
By dannyj74
Hi new to the group.
I just picked up a C81 that needs alot of tlc.
The wiring harness has been butchered pretty bad. Are there any aftermarket ones I could purchase?
By The Gman
Finished up work on the A800 ranger. Time to figure out the c120.
The ranger got;
Complete rewire. 👍
New points.👍
Re-timed and a new head gasket.👍
Carb rebuild. 👍
Full service. 👍
My daughter is gonna use it this year. She has just under 1/2 an acre to cut.
Now the challenge is the c120. Picked this up in Jan. Price was right and I was really just after the motor but the rest of it just had to come home too. Not sure if it's all there but the fun will be in finding out. So far I figure a broken clutch pedal and one rotted tire. The po had already taken it apart to restore but other things got in the way. The motor is stout and roars like a tiger.
I'm gonna put it all back together first...... fix what I find then tear down to restore.
It's the transmission I don't know about. Po said it works fine......... Hmmmmm.
Don't know much about them at the moment but "forum" research ans help here I come!!!
Transaxle oil is low but clean and the tow valve doesn't look like it's been loosened for a while. The frame sat outside for a year.
Thought I might change the oil and run it with an electric motor to see?????
The axles are free and smooth.
Anything I should be careful of?????
By The Gman
Help time please....
The k301 for my c120 (bought the tractor literally in pieces but all there I think???? ) is missing the fuel pump. I've check the engine out with the ol intravenous method and its . Ebay will sell you one for anywhere from $20 - $160. I know you get what you pay for but....... really?????
Isave tractors has one in the $50 range. Any experience with the plethora (is that really a word??) of 301 pumps out there?
