-1badr6- 0 #1 Posted May 27, 2015 Thanks guys. I am looking at purchasing a 520H. I have a fairly small yard. Have a craftsman mower that has done me just fine. I have found myself using it for a lot more than just mowing.Looking to use it for snow plowing my driveway, rototilling our garden and hopefully using the sweeper for leaves.Anyways, I am looking to see what year this tractor is. The guy who owns it does not know.Thanks. Share this post Link to post Share on other sites
Shuboxlover 485 #2 Posted May 27, 2015 (edited) 88 or 89That 520 does not have swept front axle or steering reduction. Looks like it's been well cared for though!!! Edited May 27, 2015 by Shuboxlover Share this post Link to post Share on other sites
-1badr6- 0 #3 Posted May 27, 2015 (edited) That is what I thought. It is a 1/2 owner tractor. Son got it from his dad. It has 1000 hours on it, comes with a tiller, snowblower, wheel weights, plow and sweeper. All look pretty much brand new.Wants $2000, what do you guys think this is worth.Thanks Edited May 27, 2015 by -1badr6- Share this post Link to post Share on other sites
bmsgaffer 2,069 #4 Posted May 27, 2015 1000 hours is a lot on an onan, but it looks like it was meticulously maintained. The attachments also look pristine, so I think $2000 is not out of line, but may be high. tall chute - $450weights - $75blade - $150sweeper - $100tiller - $350that leaves ~$900 for the tractorThe 520 doesnt have the swept front axle (more highly sought after), but looks fantastic for 1000 hours. If you can do a compression test and verify 95psi+ on each cylinder it would easily be worth that price. If not you could be staring down many hundreds of dollars of engine work or replacement engine if its on the edge of loosing a rear valve seat. Its not a guarantee that it will loose a seat but seems to be common on the wheel horse Onan's. Some go 2000+ hours with no issue.If you could get it for $1500 I'd say it would be a no-brainer, $2k may still be a good price. Hope that helps!Welcome to Redsquare! 1 Share this post Link to post Share on other sites
-1badr6- 0 #5 Posted May 27, 2015 Greatly appreciate the information. I can easily do a compression test as long as it is easy to access the plugs.I will go see it and make sure that it is as clean as it looks and do the test. Once again thanks for the information.Thanks. Share this post Link to post Share on other sites
bmsgaffer 2,069 #6 Posted May 27, 2015 Just so you know, that plow is not correct for the tractor (looks like it was for an older short-frame model tractor), but it does appear to have been modified to work. Check that the deck turns smoothly and quietly too.I forgot to add in that those hubcaps if free of pitting are worth $100+ and the deck can be anywhere from $75-300 depending on how it looks up close. Check for rot, cracks, or other damage. I will let someone else here chime in on the numbers for the compression test (make sure 95psi or so is what you are looking for) and if its easy to access the rear cylinder. I have yet to compression test my 520 (its sitting in the garage awaiting its time). Share this post Link to post Share on other sites
cleat 8,792 #7 Posted May 27, 2015 Also make sure you get all the little bits like the lift link for the blade, lift rod for the blower, idlers for the tiller etc.Cleat 3 Share this post Link to post Share on other sites
Tankman 3,528 #8 Posted May 27, 2015 1000 hours is a lot on an Onan, but it looks like it was meticulously maintained. The attachments also look pristine, so I think $2000 is not out of line, but may be high. If you could get it for $1500 I'd say it would be a no-brainer, $2k may still be a good price. Hope that helps!Welcome to Redsquare! Ditto. Go for $1500 but, $2000 isn't that terrible. Share this post Link to post Share on other sites
truckin88 104 #9 Posted May 27, 2015 Due to China and the internet repowers are much cheaper than 5 years ago. If everything check out 2k is not far off, the hubcaps are worth 100-150I would offer 1500 and settle at 1800-1900. That's a once machine. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #10 Posted May 27, 2015 I wouldn't go over $1500, even with all of those attachments. It does look like it saw regular maintenance so that is a plus. I had an '89 and it was a very good tractor. 1 Share this post Link to post Share on other sites
