tooltime1
520 xi toro/WH
tooltime1
Hi, I  have a 1998 , toro /wh 520 xi. Has a Kohler 20 HP,  445 hours, recently, the battery light comes up  on the dash,while mowing after a hour of mowing, battery is completely drained, and will not start tractor without a jump start.
1) i replaced old batt with new battery
2)cleaned connections
3) same issue,with dis charging, with new battery install
voltage check  at battery not running = 13.36v
voltage check with engine running  half throttle = 12.1   and the longer the eng runs the lower the volts drop,light on dash comes on, and if i mow,battery is dead in 1 hour.
Any ideas what i can check or do? Thanks jim
gwest_ca
Here are some detailed wiring diagrams you can download.
http://www.wheelhorseforum.com/files/file/3737-tractor-1998-520xi-520xie-wiring-detailedpdf/
First check to make
Turn the ignition switch to the RUN position without the engine running.
Record the voltage across the battery posts.
Now go to the voltage regulator on the engine and check the voltage on the violet wire to the B+ regulator terminal. It should be the same as the first battery voltage check. If not that likely is your problem. This test checks the path the charge current takes to get to the battery.
Let us know what you find because there is more.
Garry
shallowwatersailor
The regulator is under the engine on the left side.
  • Similar Content
    • tntatro
      By tntatro
      The stator and flywheel on this engine are different than others I have worked on so far. The stator is smaller in diameter and has a wire that runs out to a part that looks like an ignition coil but has no plug wire. I am wondering what it is and how do I wire it?
      I'm not 100% positive that I put it back in the same spot it came but I think I did. I gapped it at .020" from the bump that sticks out on the flywheel, it is magnetized.
    • koalassquad
      By koalassquad
      My wheelhorse 314-8 won't charge the battery while its running, it used to but now it doesnt. The wiring is stock as it came from factory. Runs good, just have to jump/charge It every time
    • kayvonmansouri
      By kayvonmansouri
      Hey all I'm a new member in SLC.  I ran my 416-8 tractor in a parade, and had a power inverter hooked to the battery to power a smoke machine.  It worked at first but quit working part way through.  Now the battery doesn't charge.  it runs just fine because I have it hooked to a battery tender in-between uses.  But I want to fix it. Would you start with the inverter, regulator or somewhere else,  and how would you test these?  I do have a volt meter.   Any suggestions on where to start are appreciated.
      Thanks,
      Kevin
    • meadowfield
      By meadowfield
      just how much should the ammeter be bouncing when the engine is on tickover?
      It's a new rectifier and charging fine at 14.4V, but this meter is really twanging around.
