BenBen's416
416h Ignition Switch, Safety Switch, Fuse???
BenBen's416
1995 - early model 73420, 416h, P216 - 900+hrs (New owner - 3rd mow)
Tractor just died on me and left me stranded 3 blocks from the house... it just quit exactly like I'd turned the key off. No sputter, no hiccups, no warning lights, just 'off'. Turn the key and there's no power, no lights, no indicators, nothing. My 'thoughts' were ignition switch, blown fuse, safety switch (jumping-starting was futile). When checking fuses, the 25amp fuse came out with a part of the coupling+wire attached... there's more crud, dirt, crap, corrosion than I expected - it's bad! However, I 'think' the fuse 'issue' was a result of me pulling the fuse & not the initial cause of my breakdown. Wish I had taken pics - but the weather/storms came and forced me to out & they are due to return today.
So I'm in a bind lol. My 'plans' are to get through this year, then work on this thing extensively with my son this winter... clean, rewire, maintenance the Onan, etc. I plan(ed) to spend some $ but would like to just get what I need to get me going/thru. So far, I'm ecstatic with the tractor. Got my pulley's, belts, fuel cleaned up, oil... new blades & Burtha was knocking it out great until this happened. Engine sings (sung) to me. Think I'm loosing trans/hydro oil but there's no oil loss/burn with the Onan. And Thanks fellas! When I figure this thing out, it'll be because of all the hard work the jockeys have put in with the extensive database of knowledge here on RS! While I was ready to start kicking a horse yesterday, I stepped away, came here (actually verified what I had been 'thinking') and got a game plan.
Does anyone know/have a cross-reference part # for Toro ignition switch #116338 (according to the parts manual - that's the one I need). Need a Gates# or something other than a NAPA # - but I'll take what I can get.
What are the better/quicker/serviceable ways to get this thing going? I know I'll have to rig up some new fuses for the (2) that are in the fuse block, they're shot. Also, I've researched for 5hrs on here today plus a few hrs last night & see/learned that the 9-pin is a problem area too... There was at least one snipped line behind the dash, but not the hour meter lol...
Edited by BenBen's416
gwest_ca
The 116338 ignition switch is for the magneto ignition on Kohler powered 416's
Believe you need switch 111216 which was replaced by 103990. This latest number is well recognized by aftermarket suppliers.
Repost the model number and serial number if you want us to check further.
Garry
rmaynard
Your problem can best be diagnosed with a multimeter or test light. The diagrams found in the electrical demystification guide are an excellent source of help in finding the problem. Your "start" and "spark" circuits can be found on page 7-57. Demystification guide can be downloaded here:
http://www.wheelhorseforum.com/files/file/10-demystification-guide-1985-2001-492-4509pdf/
Your ignition switch should be a #103990, available from Toro, any Toro parts dealer, or any online garden tractor parts dealer for about $18.00.
BenBen's416
Thank you!!! Locating one now. Looks like Stens #430-512... getting some sealed fuse holders for my fuse block bypass/fix too.
Thanks for the demystification guide - I'll put it with the parts catalog, manual, hydro manual, other RS threads, etc. that I've printed. All my info is at home (seems like I need to have a 2nd copy here at work lol), along with the serial/model #'s.
BenBen's416
No productive luck... I'm not worried about aesthetics right now, just want it going! (for now)
Removed the fuse block & tied (2) sealed fuse holders in (to replace the fuse block - image 5)
The red wire was free/pulled-out of the 9-pin (already dis/re-connected to my new fuse holder), I jumped it directly to itself & around the 9-pin (as it looks like that link/junction had gotten hot/black - image 4).
Turned the key - now I get a brief/quick flash on the 'Seat Safety Switch' indicator & a 'click' from around my new connections... re-did them, same symptoms/thing.
Tested the ignition switch (and couldn't/didn't get my light probe tester to 'light' on the S post... followed it to the starter, couldn't get a light there either. (image 3)
Cheese & Rice this thing was/is filthy (image 2). The loose wire here I believe to be to the test button.
Couldn't tell what the splice off of the + was (image 1)
Please help and feel free to talk to me like a 4-yr old. Seems I can't even figure out how to do a credit card payment on RS to become a supporter lol...
BenBen's416
Original BOS...
Model: 73421
Serial: 5900122
Save Old Iron
note to self - call stock broker in the morning and buy extra shares of Molex and Packard Terminal.
Please use 30 amp rated fuse holders to rewire. They will be your best assurance of long life in the 416 wiring harness.
Edited by Save Old Iron
BenBen's416
​Indeed lmao, and go ahead and get some in 3M too :laughing-rofl: ...
Will do, along with some proper connections after I give it the trailer-of-shame ride back to the house.
BenBen's416
I've cleaned all the 9-pin, relays, fuses etc, put in a new ignition switch - get nothing. Still just a click & you can 'feel' the relays working when the key is turned.
Finally, I c
rossed the + post to the small light blue wire post ('signal(?)'/authorization) on the starter - she came to life and made all the way home! Feel better about that, but now I need help figuring out the rest/cause. I've reviewed countless hours on here and it's helped a lot, but reading the wiring diagram is like me trying to prepare a Canadian Tax Return in French... using roman numerals.
Ideas??? By the looks of the diagram - my guess would be the 'start relay'...
Didn't engage the PTO to see if it's that switch. I'm just drained & plan to work on it tomorrow... Direction is appreciated.
Can someone clue me in to what the wider disconnected wire is? (don't see where/what that would-be/was attached to before/originally)
gwest_ca
Here is the wiring diagram I'm looking at
http://www.wheelhorseforum.com/files/file/4495-tractor-1995-416-h-wiring-detailed-492-4509pdf/
I did not look it up this time but believe there are 2 identical relays used for 2 different circuits.
The starter relay has
Dark blue wire
White wire - This is likely the one you are asking about and the reason the starter blue wire is dead. There should be one terminal not used so you have to get it on the correct one.
Black wire
Light blue wire
The seat relay uses all the terminals and has
Orange wire
Dark green wire
Black wire
Yellow wire
Brown wire
If the starter relay already has a white wire the loose one should be the other end and powered by the 30 amp fuse in the fuse box.
Garry
Edited by gwest_ca
BenBen's416
Put the light indicator/tester to the white wire post in the start relay (relay on the right of the fuse block if you are sitting in the seat). Nothing... pulled the splice (above in 'image 1'). Reconnected the wire to + battery post. Got a signal at the relay. FIRED RIGHT UP.
Thanks for all the other posts/threads in this forum ... feel good. Mowed today & did fine.
  • Similar Content
    • razorback1995
      By razorback1995
      Hey all,
      This pully blew up on me yesterday. Having a hard time IDing the part # or replacements. the 308-8 schematics I've found don't list this part.  Its the pully in the front that runs from the motor to the mowing deck.
      Thanks in advance!
    • Jeff-C175
      By Jeff-C175
      I'm thinking of replacing the keyswitch on my machine with a toggle and a pushbutton.  I need to replace the keyswitch again and can't seem to find something that meets my quality standards.
      I'm open to sourcing suggestions for a QUALITY keyswitch of course, but in the meantime:
      I'm going to check my existing switch later today, but thought I'd put this out there.
      Does the keyswitch 'BREAK' the rectifier (regulator) connection when going to START as in the bottom schematic as opposed to the top?
    • Bach-Ed
      By Bach-Ed
      It's been a while since I've been here.  My 857 just keeps humming a long.  But a while ago I picked up some parts, thinking they would fit my machine but no.  so here are some pics  they seem to be NOS.   I'm sure one of you would love to have them and I would have a little more shelf space.
    • Canaaner
      By Canaaner
      Ran fine all summer, no blows the dash fuse (10 A) once it's started. Will run momentarily then, fuse blows and nothing. Replaced fuse, ran for a minute then fuse blew again. Any help?
    • craigbic
      By craigbic
      Tom, one of the owners of Boyden & Perron of Amherst, MA, the Master Toro/Wheel Horse dealer who sold me my 1998 314-8 Wheel Horse Garden Tractor came out in the middle of a snow storm, at night, after a full day of work,the night before Thanksgiving to fix my tractor when it broke down after 30 feet of snow blowing. Turns out, when I got out of the cab, I kicked the gear shift which caused the safety switch to turn off the engine - as expected. I'm a big guy and new to the more compact nature of the WH controls and the confines of a snow cab.
      Apparently, when that happened, the magnetic part on the gear shift broke off. I'm new to wheel horse and had no idea and since I only had the tractor for just shy of 24 hours and I was standing in the dark in the snow with now way to get my car up the driveway (it's a Honda and doesn't like steep grades and snow - both describing my driveway), I gave them a call figuring he could walk me through some stuff on the phone. He did but none of it helped, so to my surprise he came out.
      Unfortunately, when he got to my house, because it was dark and snowing and the mailbox is in between my driveway and my neighbors and a bit confusing, he chose the wrong driveway and being even steeper than mine and not plowed, he slid off into a ditch. He than walked over to my house to get my tractor working again (we jumped out the gear shift switch) and then he called a co-worker to get him home. Unfortunately, he had driveways to plow with that tuck and couldn't get it out until Thanksgiving.
      Some time on Thanksgiving morning, when he came to get his truck out, he delivered my tractors bagger tube that got left behind when he delivered the tractor. I felt SOOOOO bad for Tom but that just speaks volumes about the level of service you get from Boyden & Perron! I can't recommend them enough!
      Here's a video of the poor guy testing out the tractor to make sure all was ok (and probably to kill time waiting to be picked up).
