DaleLicht
48" SD Model# 05-48MS03 pulley idler placement
DaleLicht
Happy Memorial Day Everyone!    :USA:
I am rebuilding my 48" Mower deck and am wondering which mounting hole to use when reinstalling the idler tension pulley? There are two holes; and outer and an inner and they are about 2 inches apart. I am also wondering how you know when a spindle bearing has worn out? The 3 blade spindles seem to move freely, but the center spindle pulley looks a little out of round when you spin it. I try to me a minimalist and not fix it if it aint broke. The deck was noisy when I disassembled it and the complete tension system and belt were broken and in need of replacement.
Thank you for your help....
scraper
Go to partstree.com and type in the model number for you're deck, you can the get a exploded view as to where the pulley goes. The spindles should have no play of any kind, and when you spin them the bearings should feel smooth an free. If the feel grainy or have a sandy feel to them the bearings should be replaced.
DaleLicht
Yes I have the diagram which indicates the idler pulley goes on the inner hole, but when I removed the pulley it was on the outer hole. I have switched them and tried the mower and the pulley system is fine and working as designed, but when I put it back on the tractor I am getting a noise from the deck like the blades are hitting something in the rotation. The spindles seem tight and move freely with no wobble. When I pull the deck off I cant find anything that looks worn or where it is hitting. Any suggestions on how to trace the knocking noise when the deck is off the tractor?
Thank you, :eusa-think:
cheesegrader
I had this problem when I cleaned up a deck that I got last year.
If the blades are hitting something, they will leave an obvious mark on the inside of the shell (like a baffle that is bent or no longer solid)
More likely, you have a loose blade, a blade that is out of balance, or a blade that has a stripped mounting hole.
cleat
My 42" deck was like that as well after a rebuild including adding a large stiffener plate similar to the 48" deck.
The stiffening plate slightly raised the idler assembly and it was hitting the belt guard with the mounting bolt in the idler pulley itself. I ground 1/8" or so off the top of the bolt and problem solved.
Cleat
DaleLicht
When I took the deck apart I inspected the deck for signs of a blade scrape, and couldn't find anything. I replaced all three blades with new ones and they are not loose, and the mounting holes are not stripped or damaged in any way. I will remove the guards and test the mower to see if they are the problem, but nothing has changed in regard to the height of the pulleys and this is the same issue I took it apart for.  The deck is solid but I will also look for a possible baffle that is moving when the deck is engaged. I am running out of options except to change the spindles one at a time to see if they are bent, but you would still see where the blade is hitting the housing. Any other suggestions?
Thank you,
:eusa-think:
daveoman1966
Banging noise sources: 1) spindle shaft moving up / down in housing 2)Flat bar of idler pulley slopping back/forth or sideways in its stanchions...3)wobbling pulley 4) maybe the spindle belt isn't tight enough and it is banging around.  Here is a pic of what the 48" deck ought look like....note how far the spring is stretched, and how close the 4 1/2" idler pulley is to the end stanchion.
If you need ANY parts for this deck...contact me at:
daveoman@windstream.net
Don1977
Did you check the nylon bushings on the idler slide?
scraper
That is a good idea, check the plastic bushings on the slide like Don1977 said, there are 4 of them. They were worn out on my deck. Also, check the bearing on the idler tension pulley, make sure it has no play and is not loose. If it is worn that might be making some noise.
DaleLicht
When I rebuilt the deck, I replaced the nylon bushing for the idler pulley and everything is tight, isn't hitting and looks good there. There is no play in any of the spindle shafts unless it is only happening when engaged at high speeds. I am going to remove the pulley covers and inspect it while it is running from there. I should be able to tell where the noise is coming from by doing that. Thanks for the help and the pic.
Happy Memorial Day!!   :USA:
DaleLicht
Just an update, when I removed and inspected the deck from underneath, the center blade had about two inches of play in it before it engaged the pulley, I took it apart and found a broken spacer, and the center main pulley is worn down on the center wear it contacts the bearing. I am replacing it all and will let you know the outcome.
Thank you,
cleat
how did it turn out ?
Cleat
DaleLicht
Well Cleat, I am glad you asked. After I discovered the broken center spindle, I began the hunt for a new replacement one only to find that they are ridiculously expensive. In my search, I reached out to Daveoman1966, one of the previous Wheelhorseforum supporters that had helped me diagnose the problem and had written that he had replacement parts for that mower deck. Daveoman1966 had the Spindle that I needed at about half the price of a new one, so I purchased it and installed it in the deck. Unfortunately after it was installed I noticed a slight amount of play in the replacement spindle bearing which was unacceptable and I once again had to rip the deck apart. Daveoman1966 was apologetic and shipped a replacement spindle to me via 2day USPS. I finally installed the new spindle and put the mower deck back on my Wheelhorse and have been cutting the lawn happily ever after.....the End.
Thanks to everyone who contributed to the thread. I really appreciate it:text-thankyoublue:
  • Similar Content
    • Snoopy11
      By Snoopy11
      Hello my fine people,
      A while ago I got a PM from a member who was not familiar with packing bearings on idler pulleys. I told that particular member that I would make an instructional thread about idler pulleys, so here we go.
      Repacking idler pulley bearings only applies if your pulleys move correctly. That may seem obvious, but let me explain further.
      Pulley movement is a good sign that your pulley is still functional and sound, but that is not the end of the story. If your pulley freewheels, that is, you take the pulley and spin it, and it has no resistance, that means that your pulley is probably good, but needs to be repacked with grease. However, if you lay the pulley flat on a workbench, and attempt to move the inside bearing race side to side, left to right, and there is obvious movement, your pulley bearings are bad and I recommend you invest in a new pulley.
      Investing in a new pulley does not mean that you are done. You still need to pack the bearings. See below for instructions.
      If your pulley does not move at all, the chances are that the inside of your pulley looks like this, and you must invest in a new pulley.
      Step 1 in repacking pulley bearings on an OLD idler pulley is to remove the dust caps from the pulley bearings. You can do this with a small pick, but I have found that a combination of a box-cutter blade and very small scewdriver works perfectly to remove the caps. Be careful not to damage the dust caps when you remove them, or bend them excessively.
      The next step is to clean the bearings out with the penetrant oil of your choice. My choice is PB Blaster because that is what I have in stock.
      Bearings before cleaning:
      Same bearings after cleaning:
      Much better, right?
      If you desire, you can take a stiff toothbrush and get into the bearings a bit to clean them even better. Make sure to flush the bearings very well with your penetrating oil.
      Dry the pulley and bearings as best as you can before proceeding to the next step in repacking.
      The next step is to get yourself a very small screwdriver, and use the grease of your choice (I recommend Lucas Red and Tacky). Press the grease into the bearings until the bearing area of the pulley is full of grease. Turn the pulley over, and do the same thing to the other side of the pulley, packing grease on the other side of the bearings.
      After pulley is full of grease, press the bearing caps back into place with 2 small screwdrivers. Ensure that the caps go all the way in, squeezing out a bit of grease around the edges of the pulley bearings.
      Wipe the excess grease off the pulley.
      You will notice that the pulley bearings have MUCH more resistance to movement. This is completely normal, and is exactly what you want.
      You have successfully repacked your pulley bearings!
      Special thanks to @peter lena for teaching us all about greasing our machines!
      Don
    • Barbara
      By Barbara
      Need clutch idler pulley for 312-8 lawn tractor and was told today they no longer make that part. Is there a substitute, or does anyone have a spare laying around??
    • dambur
      By dambur
      I need to change the Drive Belt on my Wheel Horse 208-4SB Model 42-08B401.  I really need some step by step instructions or a service manual. I can't seem to find the procedure anywhere.  PIctures would be great.  My mower is slow going forward and It was suggested to me to change the drive belt.
      Thanks
