WHwest8597 85 #1 Posted May 13, 2015 Does anyone have a picture installing a drive belt on a 314-8. I also noticed the tractor will not start after installing belt. Do the switch interlocks go bad often? Share this post Link to post Share on other sites
Racinbob 12,422 #2 Posted May 13, 2015 I don't have a picture but putting on a drive belt is pretty straight forward. Assuming you mean it won't crank now I would first make sure the PTO is fully disengaged and everything else is 'right' for it to crank. It would be pretty hard to knock one of the safety switches out of place doing the replacement but check them all out. Share this post Link to post Share on other sites
heysavoy 22 #3 Posted June 4, 2024 On 5/13/2015 at 9:05 AM, Racinbob said: I don't have a picture but putting on a drive belt is pretty straight forward. Assuming you mean it won't crank now I would first make sure the PTO is fully disengaged and everything else is 'right' for it to crank. It would be pretty hard to knock one of the safety switches out of place doing the replacement but check them all out. WHAT ALL HAS TO BE REMOVED IN ORDER TO REPLACE THE DRIVE BELT? THANKS Share this post Link to post Share on other sites
