16 Hp Kohler K-341 Rebuild or Junk?
By
oliver2-44, in Engines
Similar Content
By oliver2-44
I have a few few Kohler K Series 4,-12,16HP overhauls coming up. I feel sure they will need to be bored and maybe crank ground. I have the Kohler service manual and have looked at some overhaul threads on here. So my question are:
1. Do you replace the plastic governor gear during a Major Overhaul
2. Do you replace cam shaft bushings?
By Deadguy
So, today two more horses followed me home. These critters sure are friendly! Somebody should have warned me that they breed like rabbits! Anyways, the first is a B80 with the 8 speed and a 16hp Kohler. The metal is straight and it runs strong. It does need a governor adjustment and the voltage rectifier needs to be hooked up. The tires look ok, but they are very hard and are starting to crack. The second is a Charger 10 with hydro trans, an 8hp Kohler that smokes a little, and duallies. This tractor needs a new voltage rectifier, one new rear tire, and an engine rebuild or new engine. These tractors came as a package deal with a bunch of parts, including a couple mule drives, a 30-some inch universal snow plow, and a 38" triple blade rear discharge deck. $400 took it all home. How do you think I did?
By Monty72
I've just bought a WH with a K341 Spec 71113A. It has started to smoke around the air intake and while investigating I found this screw loose. It is below the exhaust and behind the throttle arm. Does anyone know what this is and what it should be attached to internally?
