fast88pu 3,325 #1 Posted May 10, 2015 Well I'm thinking about pulling with one of my gt 14s. Should I try the hydro one or the one with the 8 pinion 8 speed in it ? Or is it not even worth trying ? Thanks Share this post Link to post Share on other sites
baerpath 517 #2 Posted May 10, 2015 Use the 8 pinion not the hydro Share this post Link to post Share on other sites
fast88pu 3,325 #3 Posted May 10, 2015 Could it still be used in the stock class ? Share this post Link to post Share on other sites
baerpath 517 #4 Posted May 10, 2015 Depends on the club and what your gonna pull. Do they offer a off the lawn class ? Share this post Link to post Share on other sites
fast88pu 3,325 #5 Posted May 10, 2015 Guess this is stuff I would have to check on. I got your yellow and black Gt running last week baerpath Share this post Link to post Share on other sites
baerpath 517 #6 Posted May 10, 2015 That's good How's it run? Share this post Link to post Share on other sites
fast88pu 3,325 #7 Posted May 10, 2015 Runs good. Had to rebuild carb and fuel pump and fix gas tank. Hydro is good and lift works Share this post Link to post Share on other sites
Wheel Horse Collector 47 #8 Posted June 3, 2015 NO HYDRO!!! They make TERRIBLE pullers. Share this post Link to post Share on other sites
fast88pu 3,325 #9 Posted June 3, 2015 it is a gt14 with an 8 pinion 8 seed in it Share this post Link to post Share on other sites
octfst 378 #10 Posted June 4, 2015 Some clubs have tire size rules. most likely only 12 inch. Share this post Link to post Share on other sites
baerpath 517 #11 Posted June 4, 2015 If it came from the factory we allow upto 9.5x15 in stock classes most NY clubs allow it also. Share this post Link to post Share on other sites
fast88pu 3,325 #12 Posted June 6, 2015 Thank you Duane. Wish me luck I'm gonna give it a shot Share this post Link to post Share on other sites
jimt1971 237 #13 Posted July 21, 2015 How did you do? Plus, we need pics of the tractor. Share this post Link to post Share on other sites
Rob R 970 #14 Posted July 21, 2015 On 6/6/2015 at 8:10 PM, fast88pu said: Thank you Duane. Wish me luck I'm gonna give it a shot Heh Kyle, don't break your machine .... you just got everything going good, have fun be safe assume you need to do a wheelie bar? Share this post Link to post Share on other sites
Rob R 970 #15 Posted July 21, 2015 On 7/21/2015 at 2:58 PM, rgrottk said: On 6/6/2015 at 8:10 PM, fast88pu said: Thank you Duane. Wish me luck I'm gonna give it a shot Heh Kyle, don't break your machine .... you just got everything going good, have fun be safe assume you need to do a wheelie bar? On 7/21/2015 at 2:58 PM, rgrottk said: On 6/6/2015 at 8:10 PM, fast88pu said: Thank you Duane. Wish me luck I'm gonna give it a shot Heh Kyle, don't break your machine .... you just got everything going good, have fun be safe assume you need to do a wheelie bar? By the way which GT4 do you like the best Hydro or Gear and why? Thanks Share this post Link to post Share on other sites
fast88pu 3,325 #16 Posted July 21, 2015 I haven't pulled yet with it. I like the Hydro because of the lift but the 8 speed is nice to pull the cart around with and it books in 3 hi down the road. Would say it does between 15 and 20 mph 1 Share this post Link to post Share on other sites
fast88pu 3,325 #17 Posted October 24, 2016 Well I tried the gt14 with the 8 speed for pulling in the begining of the year and it did not do as well as I hoped. My 312-8 out pulled it. The problem is the lack of tread patterns available in in size and they are nose heavy. 1 Share this post Link to post Share on other sites
kthack657 279 #18 Posted February 11, 2017 My husband Jim buiLt a custom GT-14 last year for pulling...long story ahort after everything it is apart and he built a 520 i stead...with an 8 pinion rearbof course Share this post Link to post Share on other sites
