C-165 Clutch Pedal takeoff and braking too suddenly
By
DaleLicht, in Transmissions and transaxles
Similar Content
By cJ_3D
Hello everyone!
Thought I would post a new thread on this as I wasn't able to find the information I was looking for. But I'm trying to get this drive belt on my 252-H and no matter what I try I can't get it on. I got a 1/2" x 76" so I know its the correct size belt. I followed the steps outlined in the manual which I've attached, and is shown on page 15. So I loosened the cross bar nuts and the flat idler adjustment pulley. And followed the routing from this guide: http://outdoorpowerinfo.com/repairs/wheel_horse_hydro_252-h_drive_belt.asp
I just can't get enough slack on it to get it over the engine pulley! Right now it's pinched up between the body and the pulley so possibly I can't get enough leverage, do I need to somehow work it from below the pulley? Doesn't help the pulley keeps coming off the shaft so I have it propped up using a scissor jack which is cumbersome to work around. I don't have a shop or anyway I can think of to safely stand the mower up and not sure about tipping it on it's side. Anyone who has done this particular belt on this mower before have any tips or suggestions for how to get this thing on?
Thanks for the help friends!
CJ
492-4003 Eaton 7 & Peerless 1320 SM.pdf
By drewd
Hi All, I have a 71 or 72 Model # 101006, Serial # 790336. Model number chart says 71 but the paper for the engine has a print code 72. The closest I could find was for models 1-3745 & 1-3741.
Two questions. I finally need to replace the drive belt. This manual list the belt as # 1576.
Two questions:
1) Does anyone know what size that translates to? I do have the old belt but the inside edge is falling apart so it will measure a little longer than it should.
2) This tractor has the electric clutch. What is the best way to remove the belt?
As always...Thanks!
By Mike Compton
Hi there, sorry if this is a repeat question. Anyone have a pic or diagram of how to reassemble the pulleys / tensioner, and how to route the belt? One more...what are the 4 holes for at the rear of the seat deck (above the logo decal)?
Cheers,
Mike
By Reeferred
Need help,. 244-h model 72041 newer. The drive belt keeps coming off is it to lose, to tight? Any ideas would be great
By RJ Hamner
Its been a while since I was able to work on my 416-8 rebuilt and right now the few brain cells are having a tough time.
I am in the process of putting the wiring harness back in and the problem is the clutch safety switch.
The arm with the idler wheel that engages the switch is over ridding the switch arm.
I had tried adjusting the rod from the peddle to the arm but no matter my adjustment I still have the problem
I am kinda at my wits end on this one.
Any help will be greatly appreciated
Bob
