elcamino/wheelhorse 9,358 #76 Posted June 4, 2017 (edited) This build of yours is unbelievable , the attention to detail and the step by step photos is great. Waiting on the next installment . Edited June 4, 2017 by elcamino/wheelhorse 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,196 #77 Posted June 4, 2017 I really like the change in color, having gloss black in contrast to the red, nice touch. Again, can't say it enough,phenomenal project! You are an inspiration.......Thanks 1 Share this post Link to post Share on other sites
cleat 6,786 #78 Posted June 4, 2017 You do lay down a nice coat of paint. 1 Share this post Link to post Share on other sites
"D"- Man 827 #79 Posted June 4, 2017 38 minutes ago, cleat said: You do lay down a nice coat of paint. Cleat, may I say not sure which coat of paint you might be referring to; however, the gloss black on the frame is 2 mill thick powder coat, and the red is all Rusty-O-rattle can. Thanks for the compliment. 2 hours ago, elcamino/wheelhorse said: This build of yours is unbelievable , the attention to detail and the step by step photos is great. Waiting on the next installment . Thanks Elcamino, there is plenty more to come. 1 hour ago, Oldman said: I really like the change in color, having gloss black in contrast to the red, nice touch. Again, can't say it enough,phenomenal project! You are an inspiration.......Thanks Thanks Dave, I had runs in the red painted frame and tried to sand it down to refinish and it seemed like I could not stop, soooo I knew others did their refinishing in black frames and to avoid the potential for runs in the black I opted to get it powder coated @ $75.00 it was well worth it. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,196 #80 Posted June 4, 2017 (edited) That is well worth it. I would tend to think powder coat would endure extremely well too. Now if only one could powder coat the whole Tractor! Of course you probably have a small fortune invested in this already! I'd be half afraid to drive it then! Ha ha ha! Edited June 4, 2017 by Oldman spelling 1 Share this post Link to post Share on other sites
"D"- Man 827 #81 Posted June 4, 2017 (edited) Turning Brake Transverse Shaft: 321.) Parts 322.) Support bracket right side 323.) Hex Bolts right side 324.) Installed 325.) Locknuts right side 326.) Support bracket left side 327.) Hex Bolts left side 328.) Installed 329.) Locknuts left side 330.) Bearings 331.) Installed right side 332.) Bearing installed left side {Not pictured} 333.) Shaft 334.) Installed 336.) Arm assembly right side 337.) Installed 338.) Roll pin right side 339.) Installed 340.) Arm assembly left side 341.) Installed 342.) Roll pin left side 343.) Installed P .S. I did not like the way the bearings were mounted on the inside of the support bracket plates so I had a go at driving out a roll pin and mounting them obverse from the outer side of the plates. Next: Lift Bell Crank Edited June 5, 2017 by "D"- Man 2 Share this post Link to post Share on other sites
"D"- Man 827 #82 Posted June 4, 2017 4 hours ago, Oldman said: That is well worth it. I would tend to think powder coat would endure extremely well too. Now if only one could powder coat the whole Tractor! Of course you probably have a small fortune invested in this already! I'd be half afraid to drive it then! Ha ha ha! Yes Dave, this was well worth it, this is the best powder coating of any part I have had done. I know there may be other Red Square members that have done a whole restoration in powder coat, and it certainly would be a luxury. I just started with what I had to work with {rattle cans} until I was satisfied with the results and continued to try and refinish each part this way. As much as I don't like to look back at the expense, I will admit I probably could have bought a compressor, spray gun and paint with a hardener, in it, for less money. Maybe one day! Share this post Link to post Share on other sites
"Manic-Mechanic" 1,196 #83 Posted June 4, 2017 (edited) I retract my thoughts stated earlier, now I have a question if I may pry, will you be changing out the pump for something two stage or just really rebuilding the original and treating the machine with some due respect afterwards? I had some small disappointment when my pump gave out on me, as the dirt pile was very small indeed.......still, me thinks the pump was overdue for maintenance! Edited June 4, 2017 by Oldman pro's VS con's! Share this post Link to post Share on other sites
"D"- Man 827 #84 Posted June 5, 2017 Lift Bell Crank: 344.) Parts 345.) Bell crank [This part is bent, it was the only one I had when I restored it, so that is what I used} 346.) Hex bolt {Non O.E.M. this is not listed in the manual} 347.) Locknut {Non O.E.M. this is not listed in the manual} 348.) Installed 349.) Spacer 350.) Installed 351.) Hex bolt 352.) Installed 353.) Locknut 354.) Installed 355.) Pivot bearings 356.) Installed 357.) Hex bolts 358.) Lift bell crank installed 359.) Clevis pin 360.) Installed 361.) "R"- Pin 362.) Installed Next: Hydro Lift Cylinder 3 Share this post Link to post Share on other sites
"D"- Man 827 #85 Posted June 5, 2017 Hydro Lift Cylinder: 363.) Parts 364.) Cylinder 366.) Cylinder pivot pin 367.) Snap ring 368.) Installed on pivot pin 369.) Pivot pin in frame 370.) Cylinder on pivot pin with snap ring 371.) Clevis pin 372.) Installed on cylinder and bell crank 373.) Cotter pin 374.) Installed Next: The Light Blue Painted Part P.S. Should I wait until someone guesses correctly, what it is, before posting? 2 Share this post Link to post Share on other sites
Aldon 4,827 #86 Posted June 6, 2017 Nice job! And no. Don't hold back! light Blue....hmmmmm im at a loss. Share this post Link to post Share on other sites
"D"- Man 827 #87 Posted June 6, 2017 O.K. I'LL give a hint: It mounts at the rear. 1 Share this post Link to post Share on other sites
Aldon 4,827 #88 Posted June 6, 2017 How about the rear PTO Share this post Link to post Share on other sites
"D"- Man 827 #89 Posted June 6, 2017 Aldon, that's it the rear P.T.O. pillow bearing for the shaft. 1 Share this post Link to post Share on other sites
Aldon 4,827 #90 Posted June 6, 2017 Never would have guessed without the hint:-) Share this post Link to post Share on other sites
"D"- Man 827 #91 Posted June 7, 2017 (edited) P.T.O. Pillow Bearing 375.) Parts 376.) Bearing assembly 377.) Frame mounting area 378.) Bearing mounted 379.) Washers upper 380.) Installed 381.) Hex bolts 382.) Installed 383.) Washers lower 384.) Hex nuts 385.) Installed Next: Parking Brake Lever and Rod {Bring on the bling!} Edited June 7, 2017 by "D"- Man 1 Share this post Link to post Share on other sites
"D"- Man 827 #92 Posted June 10, 2017 Parking Brake Lever and Rod 386.) Parts 387.) Parking brake handle 388.) Trunion {Parking brake lever rod to parking brake handle} 389.) Installed 390.) Washer 391.) Installed 392.) Cotter pin {Not pictured} 393.) Installed {No pictures of 394-398 as these are ditto 388-392 for another hole on handle} 394.) Trunion {Parking brake handle to neutral cam rod} 395.) Washer {Not pictured} 396.) Installed 397.) Cotter pin 398.) Installed 399.) Flange bearing 400.) Installed 401.) Hex bolt 402.) Installed 403.) Washer {Not pictured} 404.) Installed 405.) Spacer 406.) Installed 407.) Inserted into frame 408.) Hex nut 409.) Installed {This picture shows corrected hex bolt direction} 410.) Brake handle to brake lever rod} 411.) Washer {Not pictured} 412.) Installed 413.) Override spring 414.) Installed 415.) Washer {Not pictured} 416.) Installed 417.) Inserted into trunion 418.) Washer {Not pictured} 419.) Hex nut 420.) Installed 421.) Spacer {brake lever rod} 422.) Installed 423.) Inserted into lever {Not pictured} 424.) Washer {Not pictured} 425.) Installed {Not pictured} 426.) Cotter pin {Not pictured} 427.) Installed Next: Solenoid 1 Share this post Link to post Share on other sites
"D"- Man 827 #93 Posted June 17, 2017 Solenoid: 428.) Parts 429.) Solenoid {Non-O.E.M.} 430.) Mounting holes 431.) Solenoid on frame 432.) Hex bolts 433.) Installed 434.) Locknuts 435.) Installed {Bit of bad lighting in this pic.} 5 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,196 #94 Posted June 21, 2017 (edited) "I can hardly wait to see more"! Excellent! Now, are those parts chromed? If not, how will you prevent rust? Nice, very nice all the same. Edited June 21, 2017 by Oldman 1 Share this post Link to post Share on other sites
"D"- Man 827 #96 Posted June 22, 2017 Thanks Dave and Ritchie, So far the 3 spoke steering wheel, tie rod ends, drag link ends, valve stems, {dipstick} nipple, {cooling} fan cage, neutral return spring, parking brake handle, trunnion and parking brake to lever rod are chrome. I have many more parts that I had chromed and still need to get some others chromed. I had a bit of a less than desirable experience at the shop I was getting my parts chromed at, so I am trying to find some place sort of local to have more done. 1 Share this post Link to post Share on other sites
Aldon 4,827 #97 Posted June 22, 2017 (edited) This tractor will be awesomeness!!! I truly appreciate that your are doing such a great job of documenting it all. At at some point a newcomer to the wheel horse hobby will land on the site in search of info and you thread will be immensely helpful. kudos to you! cant wait to see the end project Edited June 22, 2017 by Aldon 3 Share this post Link to post Share on other sites
JPWH 6,151 #98 Posted June 22, 2017 I have been following and agree with Aldon. Fantastic build. Jay 2 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,196 #99 Posted June 22, 2017 Chromed. Nice! Yes, finding a local for the chroming process would be ideal. I really agree this will be a build of all builds! 2 Share this post Link to post Share on other sites
"D"- Man 827 #100 Posted June 24, 2017 (edited) On 6/21/2017 at 10:15 PM, Aldon said: This tractor will be awesomeness!!! I truly appreciate that your are doing such a great job of documenting it all. At at some point a newcomer to the wheel horse hobby will land on the site in search of info and you thread will be immensely helpful. kudos to you! cant wait to see the end project Aldon, Thanks for the kind compliments, helping others, where we can, is what it is all about, and trust me I would have never made it this far without the help of the many Red Square members' posts that I have relied on from time to time. I do still get a bit nervous that I may not have done something right and have to go back and rectify the build in order to get it back in line. On 6/22/2017 at 6:03 AM, JPWH said: I have been following and agree with Aldon. Fantastic build. Jay Jay, Thanks for the kind compliments as well. Edited June 25, 2017 by "D"- Man Share this post Link to post Share on other sites
