Butch
Tractor runs out of gas. Bone dry.
Butch
I get nothing when I turn the key. Even the lights won't come on in the *on* position.
Starter switch?
What a stinkin coincidence.
daveoman1966
Good battery?  Corroded battery cables?
Check ALL wiring connections....EVERYTHING, starting from the battery cables..
The headlights shoulb be fused...check that too.
Wheel-N-It
Did you disengage the PTO?
bmsgaffer
:text-yeahthat:  Been there, done that... More than I care to remember.
EDIT: didnt see you mention the lights. They aren't controlled by the safety switch.
Edited by bmsgaffer
squonk
Ck the ammeter connections if there is one on it. Seen it a bunch! 797109581avatar_zpscozkh9sx.gif
muz123
Battery or Fuse.
Butch
Yep yep! Thanks!
The lights make me think it's the switch. I have had a switch go bad a year ago. I never thought they went bad!
Thanks!
Butch
My meter shows the battery has 12.5 volts of juice. No lights. The lights are independent from the
rest of the tractor and they don't come one. They even have a lighted switch and no luck. The fuse
is good.
All this from running out of gas????????????
Battery or Fuse.
Both are good
DougL3
I have the same problem with my 416-8.  Luckily, I don't have enough hair to pull any out!
Butch
Squonk bad corrosion. Big hole melted through the gauge and melted the bracket in half. Wonder what caused this?
Wow! Is this the place the Doobie brothers were singing about?
squonk
Bad corrosion = high resistance= High amperage = hole blown through meter. Chalk up another one for the old timer squonk!  :)  :banana-wrench:
Butch
Ammeter had a hole burned in it from the negative side. New ammeter installed. Still no difference. No crank. No lights.
This crap sucks.
squonk
All that current that burned tru the meter may have made it thru to the switch and the harness for that matter. The starter current more than likely got high with all that resistance and melted a few more things
daveoman1966
Open safety switch...somewhere.
Butch
I don't think a safety switch would stop the lights from working.
Thanks for the good news!!!!!!!!  Should I jack up the seat and drive a new tractor under it???????
Save Old Iron
Butch,
what model tractor are we dealing with?
Do you have a voltmeter or test light we can work with?
buckrancher
Butch do you have incoming  power to the ignition switch?
Brian
Butch
Butch,
Old Iron It's an 83 C-85 8 speed. I own one of those Klein meters and it should probably be illegal for me to own it.
I'm very dumb when it comes to electrics. I also own one of those pokers with a wire that has the handle light up.
Thanks!
Butch
Brian
Brian there is power to the "I" only on the switch.   But the way I test it with a meter set to buzzer. With one lead to the negative side of the battery
and the other to the "I" the buzzer goes off. It does it in "off" and "on". With one lead on positive I get nothing at all. HOWEVER when I use a probe the handle
lights up only when connected to the POS of the battery and only to the "I". Nothing goes to the other posts.
So yes, I have power.
Appreciate your help. I still can't get over running out of gas left me with this. Of course it didn't cause it!
rexman72
I had to take my ignition switch  off and clean the terminals because when I turned the key I was getting nothing and the lights weren't even coming on
buckrancher
I think you are checking continuity with the buzzer sounding when you are using the probe with the light bulb inside one lead goes to ground always and you use the other lead to check for voltage at the terminal
wish you lived closer
Brian
Butch
I'll see if I can check the voltage at the terminal. Thanks.
gwest_ca
Sounds like the points are in the closed position which is grounding the I terminal on the ignition switch. This would be correct using the continuity buzzer of the meter.
Try your test light on both terminals of the ammeter. They both should be alive all the time. If only the battery side has power the shunt in the ammeter has failed. If that is the case you can disconnect the battery negative cable for safety reasons and then connect both wires to one terminal on the ammeter. Then reconnect the negative battery cable. That should get you running but the ammeter won't work.
Garry
Butch
I put a new switch in it. Still nothing. Thanks.
Butch
Garry
Garry I put a new ammeter in since the other one had a hole melted into it plus the corrosion was bad. Made no difference. I'll look at the points but that shouldn't
have any affect on the lights should it? Thanks!
