W/H JUNKY
commando 8 trans axle
W/H JUNKY
Hey all iam restoring a commando 8.the trans axle does not have a dip stick. I know from the pass tractors i have restored that i add oil though the shifter hole but i can not remember how much to put in. The rear end is completely empty.please help. Thank Chris.
not familiar with that model , but i have a commando 6 that has a fill hole on the backside of the transmission....have you checked yours?
Racinbob
The owners manual states 2 quarts. :)
rmaynard
The plug in the back will not give you a good indication of oil level. If it is completely dry, put in 2 quarts of SAE 90-140 GL-5 lube.
W/H JUNKY
Thank you guys. As always you guys have always help me out thanks again.
