chorusguy 227 #1 Posted April 27, 2015 started it up and its running pretty rough so I'm looking for a carburetor rebuild kit and points and condenser but the Toro dealership is not much help anybody got any suggestions Share this post Link to post Share on other sites
squonk 41,016 #2 Posted April 27, 2015 Take all of the numbers off the engine to any GOOD small engine shop. They should be able to get you what you need. Share this post Link to post Share on other sites
953 nut 55,033 #3 Posted April 27, 2015 NAPA is a good source for Kohler parts, give them a try. Share this post Link to post Share on other sites
rmaynard 15,419 #4 Posted April 27, 2015 eBay or Amazon is a good source for kits, points and condensers. Just search for "K341 carburetor kit", "Kohler K-series points", and "Kohler K-series condenser" NAPA Auto Parts should have them as well. Clean the carburetor well, and don't forget to make sure that all the little holes in the main needle jet valve are clean, as well as the inside of the tube itself. Rough running can also be a result of a worn throttle shaft. Kits also available to fix that. Share this post Link to post Share on other sites
midpack 862 #5 Posted April 28, 2015 I found carb stuff for a KT17 at a local place that sells higher end stuff, Echo, Stihl Scag and the like. I researched the numbers of the stuff I wanted first. It was in stock for not much more than I could have gotten it for from ebay Knowledge is power! 1 Share this post Link to post Share on other sites
