scraper 4 #1 Posted April 27, 2015 I am refinishing a 48" deck #78360 and I need to know what length the deck and pto belts are. Share this post Link to post Share on other sites
312hoss 0 #2 Posted April 27, 2015 On my 416-8 the pto belt is part#94-2501 and the deck spindle belt is part# 1594 or 107" long. The mule drive is 103" long. Hope that helps. Share this post Link to post Share on other sites
Tankman 3,518 #3 Posted April 27, 2015 (edited) On my 416-8 the pto belt is part#94-2501 and the deck spindle belt is part# 1594 or 107" long. The mule drive is 103" long. Hope that helps. Just peeked at my barn wall. I staple the belt sleeves there, helps my old memory. I have a sleeve marked for the 416-8 PTO belt; 5/8" x 82". The 48" SD deck, 1/2" x 107". PTO belt varies by engine and Horse. What Horse and engine are you using? On the shelf Huskee Kevlar belts at Tractor Supply, not too pricey. Edited April 27, 2015 by Tankman Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,029 #4 Posted April 28, 2015 Just peeked at my barn wall. I staple the belt sleeves there, helps my old memory. I have a sleeve marked for the 416-8 PTO belt; 5/8" x 82". The 48" SD deck, 1/2" x 107". PTO belt varies by engine and Horse. What Horse and engine are you using? On the shelf Huskee Kevlar belts at Tractor Supply, not too pricey. Are you sure the 5/8" x 82" belt isn't the transmission drive belt? Not aware of any decks that use a 5/8" wide belt. Garry Share this post Link to post Share on other sites
scraper 4 #5 Posted April 28, 2015 I have a 93 314-8. I went to tractor supply and they did not carry the belts, the ones they had were to short. Share this post Link to post Share on other sites
oldredrider 2,548 #6 Posted April 28, 2015 Auto parts stores (like NAPA) can get you almost any size belt you need overnight. That is unless you must have a Wheel Horse belt. Share this post Link to post Share on other sites
