Similar Content
By MadScientist
Hi there, I am new here and someone from the forum referred you to me. I am looking for a k341 16Hp Tecumseh and or an 16Hp "M" series Kohler ( i would perfer the Kohler) quality replacement engine. it doesn't have to look pretty , just strong enough to get the job done.
I am looking to put this on a 1 0375 Horse
I thank you for any help that you could offer,
Eric
By MadScientist
Hi all, I am new here and I am wondering if anyone could help me out. I have an old Horse CA-120 special model # 133619 in excellent physical shape with a dead engine. Is there a modern engine that I could use as a replacement for this model? I would love to get this old girl running again before the nasty winter weather sets in.
Tecumseh engine #'s
commercial duty 12Hp
OH160/ model
170182G/ spec
Thanks in advance for any help you could offer.
By John Sullivan
Hi Everyone
I am trying to locate the part number for the accessories belt that provides power from the mower deck to the pulleys to the double bagger on the 269H. Any and all help appreciated.
Thank you
John in Vermont
By John Casadonte
I have a late 90's 269H with the Kohler 17HP motor. After cutting for about 1 hour I turned it off, tried to start it about 10 minutes late and it would not crank. The dash lights turn on (oil, battery, parking brake), I can hear/feel the relay click but the starter will not turn.
All fuses checked All relays checked no broken/frayed wires
Solenoid will not engage when crossing the terminals with a screw driver and key switch in on position. Is this a defacto solenoid issue or do I need to check other things? Also, I am showing that the part number for the solenoid is: 52-435-02. i found one at http://www.milfordpower.com/R12130-Starter-Solenoid-Replaces-Kohler-52-435-02S-p/r12130.htm
Thanks in advance for any direction or advice.
John
By Bach-Ed
I have been watching the thread of using Preditor engines well my 857 had a K241 that threw a rod. Since that was not the original engine I just wanted to get a decent engine on it. i got a good price on a CH270 Kohler and figured I couldn't go wrong with Kohler. Any way I found I needed an adapter plate and got one and now the engine is in place. I don't show it but the hood just drops on. Hooray. The shaft size was wrong but I picked up a nice adapter on Ebay. Putting on the belt that was used with K241 did work but you can see in the photo how loose it is. I'm assuming a somewhat shorter belt would be what I want. Do you think I should try one or two inches shorter or???????? Oh and yes someone has altered the guard so a new one is on my wish list. Thr throttle cable is not working very well so that is my highest priority. I want to get the plow on and maybe scare away the white stuff.
