grnlark
How To: Chrome 520 Exhaust Heat Shield on Smaller Machines
grnlark
Several weeks back I was searching the net for a thread that might address the question: Will a chrome 520 muffler heat shield fit a smaller series machine? I found a few bits of information here and there, but nothing that really answered the question. With that said, I hope this thread finds some of you well.
Here’s what I initially gathered from reading the net and various conversations: the 520 guard is too long, it needs to be modified, they still offer the chrome guard new thru Toro and all guards are the same. Let me give you the accurate answers based on my recent experience. The 520 guard is a bit longer (illustrated below), depending which guard you get, it does not need to be modified at all, the chrome guard is NOT offered new thru Toro – only the black, and the guards are definitely not all the same.
There appears to be 2 different chrome guards and 1 black. One of the chrome guards has mounting holes on the outside edges and the other has the mounting holes set in a few inches from the edge (mine pictured below). I imagine they differed based on the engine – obviously. The black guard (as far as I can tell) is only offered with the holes set in a few inches from the edge.
When I bought my 310, the muffler was totally smooth with no mounting tabs welded to it for a guard. I was able to get a muffler from a 414, which was exactly identical but did have the tabs. I then took a gamble and purchased the chrome shield you see below (from a 520). I only needed to make one bracket for this to be a direct bolt-on without any modifications to the muffler or guard.
1) Piece of mild steel cut to length with three holes drilled.
2) Bracket blasted and painted with high temp black.
I slipped sheetmetal fasteners on the 4 muffler tabs and used stainless 8/32 hardware.
3) I used the factory mounting location(s) for both the guard and the muffler.
4) Both are factory muffler tab locations. On the shield, the 8/32 screw fits thru the horizontal slot without modification. Sure, its not the “correct†mounting location for the shield, but personally, I think it’s fine.
5) Attaches the factory shield mounting point to the homemade bracket. On this screw I have a stainless lock washer and nut (vs. sheetmetal fastener).
6) Is there a length difference? Yes. It is approx. 1.5â€-2â€. Quite honestly, it doesn’t bother me one bit, but that’s me – and I’m pretty picky about this stuff.
I’ve never claimed to be an expert about these later model WH’s, so if anything I’ve noted above seems to be in error, please feel free to comment. My hope is that this info helps others out in the future.
post-2562-0-83361900-1429884663_thumb.jp
post-2562-0-95326700-1429884667_thumb.jp
post-2562-0-91796300-1429884671_thumb.jp
post-2562-0-18918000-1429884675_thumb.jp
post-2562-0-36317500-1429884681_thumb.jp
post-2562-0-32475100-1429884685_thumb.jp
post-2562-0-20241300-1429884688_thumb.jp
Edited by grnlark
  • Like 6
buckrancher
Nice job I know there was a version of the 312 that came from the factory with a chrome guard
Brian
wrightorchid
looks great.  It would match the chrome hub caps nicely.
RedRanger
That tractor is sexy.
AMC RULES
Like it's sposed to be there.    :thumbs:
wallfish
Very nice upgrade!
Though it does kind of take the eye away from that waxed frame :ychain:
608KEB
That is one shiny tractor!
Racinbob
  On 4/25/2015 at 3:34 AM, wallfish said:
Very nice upgrade!
I was thinking it pulled your eyes away from that decal :teasing-whipyellow:
Seriously Matt, I like it a lot! I'm on the lookout for a chrome shield now. :handgestures-thumbupright:
  • Similar Content
    • Oddnicpit
      By Oddnicpit
      Looking for a replacement muffler for my grandfather's tractor I inherited.  Looks like they stopped making them?  Part number 92-6862.  Any help would be appreciated!
      Toro 265-H 92-6862.pdf
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • Rob R
      By Rob R
      So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
      So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
      I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock.  You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
      Appreciate all your advice as this one has me stumped......
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I just changed the muffler on my ‘69 Charger 12.
      There are quite a few Gravely 18543 aftermarket mufflers out there so I decided to purchase 2; 1 from Amazon for $45 and 1 from NAPA (7-03679) for $72. Both are made in Taiwan and while the Amazon muffler actually felt a tad heavier to me, its welded construction was poorer so I decided to use the NAPA muffler.
      To complete the installation, I needed a 1.25” x 4” black pipe nipple and a 5/16” x 1-1/4” exhaust clamp (NAPA 733-5323).
      In conclusion, it seems to me the sound out of the Gravely style muffler is noticeably quieter than the classic pepper pot. Worth the $80 to me!
      Link to my YouTube video:
    • Truckedup1
      By Truckedup1
      I have a very recently restored 1989 wheel horse 520-HC tractor with 60” deck. Family owned for over 10 years but now it’s time for another project. Please contact me with any questions I have the original 60” deck but it was rough so I sourced the current deck off this site, it really is in excellent condition for not being restored.
