Save Old Iron
What has been seen cannot be unseen
Save Old Iron
at first I thought - well ........ sandals, pick axe , hair and belt drives, 60 volts dc , undersize wiring and battery acid
there's just way too much in the way of safety advice not to pass this on (I know its 12 minutes of your life you will not get back but you have to watch the full video to benefit from the wisdom contained there in).
Edited by Save Old Iron
  • Like 4
meadowfield
I like his method of switching the power on - pretty clueless about the electric part!!!  he doesn't know all the cell sizes need to be matched....
stevebo
All I can say is OMG !!!
meadowfield
his apparent calmness to a blown up battery!
my brother once shorted a truck battery whilst tightening the terminal... the battery exploded in nanoseconds, covering him in acid and the plastic put a large gash in his chin :o
Save Old Iron
and not missing a beat in suggesting the exploded cell in the battery can be ignored, and the battery used as a "10 volt battery"
Dunning Kruger meets Darwin !!!
KC9KAS
After seeing his yard and storage, I can see he he isn't worried about safety. ..or anything else.
Racinbob
I just watched that while sitting here eating my breakfast. I'm confused. I can't figure out if I started my day off with a good laugh or if I'm in a state of shock. :teasing-tease:
Racinbob
OH WOW!!! I just noticed that he calls himself Rinoa Super Genius. Better yet, that was part 11. Now we can all watch parts 1-10. :greetings-clappingyellow:
There will be a test guys. Remember, quality education is priceless.
Coadster32
This guy is a piece of work for sure!!
squonk
Charging those little batteries at 15 amps for 2 hrs!  :scared-eek:  :scared-eek:  :scared-eek:  :scared-eek:  :scared-eek:
chazm
:eusa-doh:   be afraid ....BE VERY AFRAID !!!!!   :scared-eek:  :scared-eek:  :scared-eek:
jimt1971
"Guess now I have 48 volts!"
buckrancher
I thought the best part was watching him use a pick with open toed sandals on (dumb azz)
Brian
JC 1965
Several accidents waiting to happen. Thanks for sharing Chuck.       :thumbs2:
bmsgaffer
holy cow.
:jaw: <- Me while watching this.
Hes so young! Ill give him credit, that's innovative for knowing NOTHING of electricity and safety (and probably the $0 budget). But this is a bit (incredibly) scary.
C-101plowerpower
hm interesting, gotta watch out for the reverse charging, before you know it you'll be starting your horse in the wrong direction :eusa-doh:
Racinbob
Oh that's silly Koen. Then you'd have 6 reverse gears and only 2 forward. :teasing-tease:
shallowwatersailor
One thing for sure - luckily he is not my neighbor!
Save Old Iron
this video also provides insight into the age old question you may ask when viewing a Craigslist advert for a rolling chassis.
"I wonder why the previous owner cut a square hole in the hood?   Oh look, he also left a 10 inch C clamp under the seat!"
Save Old Iron
In the spirit of
https://www.youtube.com/watch?v=popXDFvOsLg
I have learned a new technique for drilling holes in sheet metal (6 minutes40 sec) into
Coadster32
That is a new method of adding a hole. :banghead:
Racinbob
You did it, didn't you SOI. You watched all 11 parts. My advice would be to just sit down in your favorite chair and just try to relax and think about cute little bunnies. Understand that a full recovery may not be possible at this point.
Save Old Iron
Yes. Yes I did.
3 hours and 50 lbs of /16th 6013 rod later.....
what has been seen cannot be unseen.
The homemade contactor switch made from the 2x10, door hinge and Kmart flat blade screwdriver is  - forgive the pun - burned into my brain.
  • Like 4
C-101plowerpower
i thought that he would use his "welder" to burn a hole in it and use that
Save Old Iron
I now have developed a full blown fascination with his YouTube website.
Don't get me wrong - I do see a level of talent here, but I'm looking for the the word describes what is lacking. I think I found out what is missing.
Look what sneaks into the video at 8 minutes 30.   :scared-eek:
My appetite today has been satisfied by the effort put forth to fix a power supply he blew up. I suspect he hooked up his laptop battery in reverse and blew out the protection diode across the output of the power supply.
the word I'm looking for is FINESSE.
And of course Thumper's safety tip of the day
post-1689-0-54552100-1429269872_thumb.gi
