Similar Content
By PAguy
Hello gents!
I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
Appreciate your guys help and thoughts.
By MSBiker
Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
By Berco
Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
By Brockport Bill
48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
By jmack
What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
Just shredded mine today.
