jetmandan
Built my own mid-mount tiller drive
jetmandan
About a year ago scanning my local craigslist, I found a newer Toro / Wheel horse 36" roto tiller for $50. Mounted up to my 74, C-160 after I had to trim off a bit of the rear axle mount locking bracket (it's length was bumping into idler pulley). Now I needed the mid mount belt setup, I have a well equipped shop at home so all I needed was some measurements. Built my drive setup close to member "Lost Pup" and his post here
post-11319-0-51820400-1428863771_thumb.j
The mostly finished bracket, waiting for  141 x 1/2" belt to arrive, bought off greed-bay. Will tack the set-screw shaft locks in place after belt fitted.
post-11319-0-72777500-1428863754_thumb.j
Pic from underside, spring is probably from an old bed mattress. It was just in my junk pile and looks close to being correct size.
post-11319-0-00209900-1428863739_thumb.j
Side pic of my over powered C-160
post-11319-0-25480400-1428863722_thumb.j
Tiller mounting shot, the electric lift is getting weak, has to work pretty hard to lift roto tiller. Plans are to remove and sell it off then replace with my own linear actuator setup.
Dan
  • Like 3
Terry M
Nice Job!!!  :handgestures-thumbupright:   Just gives me a few ideas too... :)
jetmandan
New 141 x 1/2" drive belt arrived, with perfect gardening weather for next few days could not get it mounted quick enough! The belt is a tad long, so I had to off-set the vee belt pulley so the belt would not rub itself into destruction. Unfortunately I neglected to get a pic of how I off set the pulleys. In only a couple hours, I was able to till most of my 8k sqft home garden before I threw the belt. When it stopped and all I could see from drivers seat was the belt off the pulleys and on the ground, was sure I had destroyed it. After getting a closer look, no broken anything! Guess I was having such a good time tilling that I had the soil so deeply tilled the the tiller pulley was getting packed with soil. Was getting late, so I called it a day.
post-11319-0-98236200-1429272779_thumb.j
Just a neat shot, sorry about the rotation and your sore neck :smile:
post-11319-0-51152300-1429272795_thumb.j
Only problem here is I ran out of gas, when I returned found our small flock scooping up all the bugs the tiller turned up!
post-11319-0-93243100-1429272822_thumb.j
None of these are great pics as the lens of my camera on the phone is scratched up pretty bad. Other side of tiller pulley is chrome shiny from being in contact with the soil.
post-11319-0-62924900-1429272848_thumb.j
You can almost see the offset front pulley here, it's moved out about 3/4" so the belt does not rub itself into oblivion.
post-11319-0-61321400-1429272881_thumb.j
Tiller was deeper then this, side sheet metal was at ground level. Soil felt like marshmallows, my boots were sinking a few inches with every step.
Dan
Crawdad
Your tilling job looks beautiful Dan. I hope that you didn't over do it though.
If I till my soil that finely, when it rains rains heavy, it will tend to puddle and run off
and not absorb well. I hope your crops grow strong this season!
jetmandan
Crawdad,
No worries about over tilling here, my property is dead flat, let it rain!
Oh look, I see a couplle blades of new grass in the tilled garden, sounds like a good reason to hook up roto-tiller again :happy-jumpgreen:
Crawdad
You cracked me up! I'm in the hills so that must be why...
Now I have tiller envy-damn! :teasing-poke:
rexman72
great work
o0Nighthawk0o
I just got a C175 with a tiller and other things. I was wondering why the pulleys were offset and now I know. Thanks. I just hope I can guess right on the belt length. I am thinking 139" should do it. I will be plowing and tilling this weekend and hope all goes well. I'm a city boy transplant to the country.
jeff lary
  That is a good looking mid mount you built nice job. I have a tiller too and it does work good enjoy. Jeff
  • Similar Content
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • morePEdal
      By morePEdal
      1989 Wheel Horse 520H
      Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
      I am in Germantown, Wisconsin.
      Comes with:
      -42” Deck
      -Two- Single Stage Snowblowers, one is attached.
      -Tiller
      -Snow Plow
      -Hard Top, Soft Sided Cab, in good shape
      -Hubcaps
      -Cast Iron Weights
      -Chains
      -New Battery
      -New Snowblower Belt
      Price: $1100
      Cross Posted.
    • Jayzauto
      By Jayzauto
      I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint.  Engine has been replaced with an identical Kohler KT-17 Series 1.  New Carb has been installed.  Battery, solenoid and cables have been replaced, starts great.  Installed new Tires and Tie Rods.  Installed radial bearings in spindles, so it steers beautifully.  Fuel line has been changed, as well as headlights.  Bew mule drive and belt fot tiller and functions as designed.  I'm sure there is other items that have been done.  Very reliable machine. $800/BRO
      Selling all my WheelHorse items and moving South.  Have other tractors ad parts if interested.
    • oliver2-44
      By oliver2-44
      Anyone have any Troy Bilt  Pony Tiller Gear Box Experience?
      So about a year ago an older neighbor gave me this Troy Bilt Pony Rear Tine tiller.  Said he forgot he drained the engine oil and started it.  Bore diameter was actually good, but has a bunch of large vertical scars on cylinder walls.
      Fast forward, my wife has volunteered us to help a Youth Summer Camp that runs an  "Outdoor School" during the 9mth  school year.  They had a fairly large garden for several years, but it has been neglected & overgrown for a couple of years.  So she drives past this neglected garden daily!
      There's some scheme emerging where we have half the garden to ourselves and help with the other half where students will plant and weed and pick their produce.  I enjoy a garden, but not real keen on some of the aspects on this one...( a bunch of 6" high raised beds with paths to narrow for my big feet to turn sideways. But I've already been committed, O I mean volunteered.
      So engine is shot (aluminum block)  but I have a Predator or a K181 I could put on it.
      The wheel shaft seals looked shot and had a bunch of play so brass wheel bushings were shot. (the other 2 shafts have tapered roller bearings).
      No model number, but from the "Pxxxxx" serial number and Briggs engine I've dated it to a 1981.
      MTD now owns Troy Bilt and their "on-line manuals" go back to 2000.  Called their Tech Supports and got "Deer in the Headlite" comments regarding a 1981 Service Manual.
      Searched online and founds lots more info on the larger "Horse" model, and a 1991  Pony service manual.
      While they basically look the same, there's been several generations of re-engineering the internals to simplify manufacturing and eliminate castings it appears.
      I found this parts diagram to be the close's match to what I have.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/wheel-tiller-shaft-assemblies-7/
      I disassembled it and I think I marked everything as to what faced the front, back or R,L side.  Internals looked OK, but the wheel shaft seal area is not the greatest.
      Most parts are NLA but found bearing. seals & bushings on ebay. $130
      Reassembled everything and used the 1991 Service Manual as a "Guide" to shimming the 3 shafts end play.
      Everything turn freely in both directions when in neutral. But when I engage the Wheel Shaft "Clutch" it binds up. The clutch lets the wheels roll freely or engages them to power.  It uses belt idlers to reverse direction from a second shaft on the briggs (like a walk behind snow blower drive)
      photo from phone here
      This internal clutch actually works by using a pawl disc which is keyed to the shaft to engage the wheel
      shaft gear which is free wheeling on the shaft.
      I've loosened the bolt on the bearing end caps slightly and no change.
      This uses worm gears and I know "some" worm gears are designed where they must be "power driven"  in each direction (My boat lift is like this)
      So the rear tine gear shaft turn freely in each direction.
      The wheel shaft locks up when the clutch is engaged amd trying to turn it in what would be the forward direction.  But it will turn freely with the clutch engaged if going in the backwards direction.
      The wheel shaft gear cannot be turned backwards because of the clutch mechanism on the one side.
      The rear tine shaft bevel gear turn freely in both direction in neutral but is bound up when the clutch on the wheel shaft is engaged.??
      There is a Main Drive Shaft that has the Worm Gears on it to drive the Wheel Gear and a second worm to drive the Tines Gear.
      https://www.partstree.com/models/20462-troy-bilt-pony-i-rear-tine-tiller-sn-p001001-p101750/main-drive-shaft-gear-assemblies-4/
      This shaft is made up of a smooth shaft with the worms keyed to it and spacers in between them.  I disassembled it (and carefully laid out each piece in order) to wire brush everything clean on the grinder as there was some rust from water in the very bottom of the gearbox.
      I find it hard to believe that I could have one of the worms backwards because it seems it would not turn freely when the wheel clutch is not engaged??
      To remove it I have to disassemble everything and might ruin my seals as I have to drive them out. (dumb me, I tested everything to turn freely before I installed the seals, BUT I didn't engage the clutch)
      Just a note,, I didn't try to turn everything with the "clutch engaged" "Before" I disassembled it so I don't know how hard it should turn, but it had to turn via a belt drive verse's now totally locking up.
      Regrettable a nonworking tiller doesn't get me out being volunteered.
      Did I say I actually enjoy a garden!
      Thanks for any suggestions and listening to my rant.
      This is the input shaft from belt pulley
      Special woodruff key
      Tiller Tine Shaft
      Some one was in here before me. These are threaded holes with removable set screws to drive the bearing cone out. No set screws just filled with caulk or body putty.
    • wh315-8
      By wh315-8
      Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
      Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
