Snow Cab Interchange on 1987 310 to a 418A?
By
white-box, in Implements and Attachments
Similar Content
By cyrus
1996 416-H Wheel Horse Garden Tractor
Model # 73423
1355 hours
Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
Pick up only.
8509515355704655080.mp4 -
By morePEdal
1989 Wheel Horse 520H
Selling my 1989 Wheel Horse 520H. It has hydro transmission and has hydraulic lift. I bought this tractor last November from the original owner with the intent to use it just in the winter. I have a 416-8 that I use for cutting grass, but also have a snow blade. I am selling this because I decided I want power steering so I bought a different garden tractor. I put in a new fuel filter, fuel lines, new spark plugs and oil was changed with a new filter put in. It has 115 compression on both cylinders. The carb needs work, but it does start and run. I no longer have room for it. 1790 hours.
I am in Germantown, Wisconsin.
Comes with:
-42” Deck
-Two- Single Stage Snowblowers, one is attached.
-Tiller
-Snow Plow
-Hard Top, Soft Sided Cab, in good shape
-Hubcaps
-Cast Iron Weights
-Chains
-New Battery
-New Snowblower Belt
Price: $1100
Cross Posted.
By lodestonefarm
Selling my trusty WH520H. ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking. 20HP Onan, hydro transmission and hydraulic lift. Has Matt's foot-pedal conversion for forward/reverse. Included in the sale is a tall-chute snow blower and 60" mowing deck. The blower is in excellent condition and is on the tractor currently. The mowing deck has been a workhorse over the years. No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo). Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it). Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front. The seat (with arm rests) isn't in great shape. I've got a cover for the seat, never used. It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
I've owed this machine about 8 year and put ~350 hours on her. She's not a show piece but could be restored. Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn. The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster. My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast. They don't make them like this anymore.
By Upnorthman
314-8 In great shape. Used for mowing more than anything. Bought it a few years ago but got a new tractor. I used the blower very little and it sounds like it needs a bearing on it. Runs well. I have new chains I've not put on yet and extra belts.
By WVHillbilly520H
@WHX24, @PeacemakerJack, @ebinmaine, @JCM, @shallowwatersailor, @pullstart, @Horse Newbie, @elcamino/wheelhorse, @Ed Kennell, and the rest of RS ....
As I have mentioned before I would be getting snow removal tools for my Mahindra eMax 22, the whole package plow, blower and soft cab, I had purchased a Kubota set-up a couple years back with the intentions of modifying it to fit/work with it but after careful consideration decided just to sell it to help pay for the correct set-up built for Mahindra (by Berco in Canada), I ordered it the end of October and its showed at the dealer in PA right before Christmas and I just picked it up Friday, and today got the sub-frame (which both the plow and blower use so you can switch between with ease) assembled and mounting brackets installed on the tractor frame (the only thing I don't like is you have to switch these brackets back and forth between this and the mower deck mounts "not quite WH easy" but after a few times it may not be so bad ), then installed the sub-frame , snow plow and ran the hydraulic lines and plugged into the loader/sector valve. The cab and blower assembly will follow within the next few days/weeks. Pics and a little video of it in operation.
20210110_163214.mp4
