SethL1984
Misfiring / Won't stay running M14 with video.
SethL1984
https://youtu.be/0_zX7Ur6quI
What do ya think guys!?
Once it starts it seems to misfire or something. I provided the video to help you hear what I'm dealing with!
Edited by SethL1984
ericj
take the bowl off the carb, probably condensation in there from the ethanol fuel it will actually raise the float level and cause  it to flood, i surmise that how it happen don't know for sure, but i know that i have fixed my neighbor's B 80 several time for same symptoms by doing this. first time i pulled the carb all the way off but after that i got smart and just drop the bowl and fixed it that way. clean the inside of the bowl and careful of the bowl gasket and make sure you start the bolt back in the carb straight. i bought a 312 one time that somebody did that to almost had to buy a new carb. good luck
eric j
Forest Road
What he said!
How old are the fuel lines? They do break down. It's worth $5 to replace them and use an inline filter as well.
Sent from my iPhone using Tapatalk
SethL1984
Thanks for the input so far!
I tried emptying the carb, havne't had a ton of time to play with it. Also, the fuel lines were replaced last winter with a new fuel filter; as well as a new fuel pump.
stevasaurus
The screw on top of the carb...screw it in until it "gently" bottoms out...pay attention to how many turns it takes...might be like 2 1/2 turns.  Then pull that screw out...there is a little hole down near the bottom of the shaft of that screw.  Using carb cleaner and a small piece of wire, clean out that hole.  Put screw back in by bottoming out and the backing back out the revolutions you counted in the first place.  If that hole is clogged or dirty...it will do what your horse is doing.
I would also take a look at your points...should be .0020...I like about .0018 on older machines.  The points control your timing on these Kohlers.  Hope that helps.  :)
squonk
Also make sure your condenser wire hasn't broken. (It happened to me! )  :)
Don1977
That is an Magnum 14 or so he posted, won't have points or condenser. Carb., fuel pump,  fuel filter, gas lines, screen in tank or tank cap not vented,  When you get it running and it's still miss firing the valves may need adjusting.
My Magnum 12 ran fine but it had a constant miss fire. I found the intake valve was at less then half of the specified setting..
Fordiesel69
Try a new plug before doing anything.  Mine just did the same exact thing and I wasted a lot of time for not.  The plug was replaced in DEC.  Fouled out this weekend.
Looking at your other videos, you had some fuel problems going on as well.  Did you ever solve those?
SethL1984
Fordiesel69 - I did solve them! Found the screen in the tank junked up, replaced that. Ended up replacing everything between the tank and carb. New fuel lines, inline filter, even new fuel pump!
I'll be sure to give the spark plug a try.
stevasaurus
Sorry, I completely missed the M at the start of this thread.  :bow-blue:
SethL1984
So the bowl clean out worked!
Anyone know where to get a rebuild kit?
SethL1984
So what does it mean whenfuel "pours" out while turning the engine over?
oldredrider
Stuck float or float valve will cause "flooding".
ericj
ethanol gas condensation build up in the bowl will also cause this i know you said you just cleaned the carb but if it was in the gas tank it could end up in the carb again as fast as you clean it out. good luck
eric j
John Galt
NAPA auto parts has rebuild kit for about 12 bucks. Also look at ebay.
SethL1984
large.IMG_2256.JPG.94c306a08ebd5d1b11104
Boom! Overhauled carb runs AWSOME!!
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • CasualObserver
      By CasualObserver
      Owners manual for the two cylinder snowmobile engines.
      12 pages 1.38MB
      1970 399 Safari snowmobile model 9-0041 - 2-cylinder
      1970 440 Safari snowmobile model 9-0051 - 2-cylinder
      1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
      1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
    • CasualObserver
      By CasualObserver
      Owners manual for the Single cylinder snowmobile engines.
      12 pages 1.33MB
      1970 295 Safari snowmobile model 9-0011 - 1-cylinder
      1970 309 Safari snowmobile model 9-0021 - 1-cylinder
      1970 309W Safari snowmobile model 9-0061 - 1-cylinder
      1970 355 Safari snowmobile model 9-0031 - 1-cylinder
      1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
    • Jeff-C175
    • nylyon
      By nylyon-(Admin)
      I think I am selling my 1987 414-8 with plow, weights and chains.  Now here’s the story on this one. A long long time ago, I was searching for a snow plow for my 416H.  In that search I stumbled onto a forum which was one day old.  There was no name of the forum, just whtractor.15.forumer.com. Trying to learn more about snow plows I started conversations with one of the active members on the site, let’s call him Mike.  Mike convinced me I didn’t need a plow, but an entirely new tractor.
      About a week or so later, I found this 414–8 for sale, and bought it.  I now had my plow and could plow the driveway. So what happened with Mike @Sparky and this forum I spoke of? It grew a little bit, and we now call it RedSquare, and for sale is one of if not THE reason RedSquare exists today, so you can own a piece of RedSquare history!
      About the tractor: 1987 414-8. Kohler M14, runs well does not burn oil. Everything on the tractor works as it should, but it is a worker. The plow is a 48” with a custom made scraper blade, made from heavier stock than original. For the past several years, this has been a dedicated plow tractor, so it hasn’t seen a lot of work, but has also sat outside (under a tractor cover) so lots of let’s say, patina going on.
      I a, selling because I just picked up a 416-8, and that will become my winter plow / blower tractor.  I am looking for $550, but like I said this tractor is a bit of a legend!
      I have cleaned it up since the pictures were taken.
