KC9KAS 4,741 #1 Posted March 26, 2015 Do we have a filter cross reference pinned anywhere?? Air, Oil & Hydro filters?? Share this post Link to post Share on other sites
squonk 41,120 #2 Posted March 26, 2015 Hydro is a Napa 1410 Share this post Link to post Share on other sites
oldredrider 2,548 #3 Posted March 26, 2015 Interesting and timely topic. I just got a BIG box full of air filters...all Kohler. It would be nice to see a chart with numbers to see which filter fits what without doing a time consuming search. Share this post Link to post Share on other sites
wh5208speed 645 #4 Posted March 26, 2015 (edited) Wheel Horse Hydro Filter Cross-Reference Wix 51410 Napa 1410 Amsoil EAO40 Fleetguard HF6096 Fram PH2844 Donaldson P550940 Toro/Wheel Horse 79-5270 If someone can tell me how to upload an excel file I will put up my whole list of cross-references that include oil, air, fuel, hydro and spark plugs. Napa is having a sale right now on their Napa Platinum's which have synthetic media and are exactly like the Wix XP line. They are normally $12.99 and I got mine for $7.99. Thad (Ohio) Edited March 26, 2015 by wh5208speed Share this post Link to post Share on other sites
wh5208speed 645 #5 Posted March 26, 2015 (edited) Figured out two different ways. 1. Print off....take a photo, turn into a PDF and then upload 2. Print off....take a photo, send as a JPEG and then upload. If someone does want the excel sheet so they can add more models I will be more than welcome to email it to them, or if someone can tell me how to upload it to the group I will. The Tractors I used are Onan Twin/WH - 520's, 416's etc Kohler Twin/WH - 417, 418, 420 with KT or Magnums Kohler Single/WH-C-161 with K-341 that has the thicker air filter with the smaller diameter. Thad (Ohio) Wh filters - Mar 25, 2015, 9-32 PM.pdf Edited March 26, 2015 by wh5208speed Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #6 Posted March 26, 2015 Something you will find with filters and spark plugs You can use the original part number and the interchange to get a replacement. If you use the makers application charts they often list a different part number than the interchange suggests because they found it to be a superior product for that particular application. I had the opportunity to be on a field survey of a large company's equipment with Wix one time and saw what went into the process. Wheel Horse/Toro filters are a good example of this. Garry Share this post Link to post Share on other sites
Don1977 604 #7 Posted March 26, 2015 The 10 and 12 HP K-series Kohler use a Wix 42373 air filter. The 16 HP and Magnum uses Wix 42299. Not sure witch the 14 HP K-series uses. Share this post Link to post Share on other sites
squonk 41,120 #8 Posted March 27, 2015 I have a 14 sittin on the bench with a Napa 2373. Share this post Link to post Share on other sites
squonk 41,120 #9 Posted March 27, 2015 Prime line 702204 crosses to the 2373 702205 crosses to the 2299 Small Block K's use 702202 or 2372 Share this post Link to post Share on other sites
