608KEB
I'm going to restore the 95 520H I bought yesterday. This is probably going to take a while. The 9 pin connector needs to be repaired first
post-5623-0-70234500-1426867158_thumb.jp
post-5623-0-78498800-1426867190_thumb.jp
post-5623-0-74008600-1426867247_thumb.jp
post-5623-0-29519900-1426867269_thumb.jp
post-5623-0-70061100-1426867293_thumb.jp
post-5623-0-01969600-1426867323_thumb.jp
post-5623-0-61824000-1426867352_thumb.jp
Edited by 608KEB
608KEB
I patched the nine pin connector. The battery is now charging. I have a 520H wiring diagram. I don't know where to start looking for the problem with the warning lights. They stay on while the tractor is running. Is it a relay switch problem?
Edited by 608KEB
cleat
All the lights ?
608KEB
Yes, all the warning lights stay on. The oil pressure light flashes, which I think is normal. I noticed the transmission warning light wire plug is broken off. That shouldn't matter.
Edited by 608KEB
varosd
you even got a bonus   the free rear axle bracket :D
608KEB
Yes, It also came with a 48" plow. The headlights and other gauges all work.
cleat
Don't know what to tell you about the indicator lights. Early models have a test switch that you depress to test the lights. Later models just cycle the lights on for a couple of seconds when you turn on the ignition switch.
I have never seen a rear bracket spaced down like yours before.
Cleat
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • HorsePower58
      By HorsePower58
