nikond3100 0 #1 Posted March 18, 2015 hi all new here looking for help on my wh414-8 no model or s number it has the mag 14 in her Share this post Link to post Share on other sites
Sparky-(Admin) 21,930 #2 Posted March 18, 2015 Welcome to Redsquare. Any pics you can show us? Mike.......... Share this post Link to post Share on other sites
nikond3100 0 #3 Posted March 18, 2015 will post soon its all apart Share this post Link to post Share on other sites
neil 2,410 #4 Posted March 18, 2015 Welcome or REDSQUARE someone will be along shortly to answer your questions , got any pics of your horse Share this post Link to post Share on other sites
rmaynard 15,892 #5 Posted March 18, 2015 hi all new here looking for help on my wh414-8 no model or s number it has the mag 14 in her What kind of help are you looking for? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,223 #6 Posted March 18, 2015 1987 414-8 used Kohler M14S-601524 in tractor model 31-14K802 1988 414-8 used Kohler M14S-601540 in tractor model 31-14K803 1989 414-8 used Kohler M14S-601540 in tractor model 31-14K804 Garry Share this post Link to post Share on other sites
nikond3100 0 #9 Posted March 18, 2015 thanks garry I have those numbers the only sticker on this wh is the tag for the seat the dat of mfg oi 03/1989 I need a clutch and the clutch break drive belt headlights fuel cap tires wheel weights and more o and in in Ontario canada Share this post Link to post Share on other sites
nikond3100 0 #10 Posted March 23, 2015 looking for wheel bearings front wheels and transmission axel seals 1989 wh 414-8 thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,223 #11 Posted March 31, 2015 Not the best illustrated parts list but all we have The original front wheel bearings are Toro # 110513 Here is a good Stens dealer east of Toronto that gives me next day service http://www.bantasaw.com/ Just do a search for 110513. They have two styles of bearing - one with one seal and another with two seals. With two seals it is best to replace the grease fitting with a set screw so there is no attempt to grease the bearing. The seal won't allow the grease into the bearing and the pressure will push the bearing out of the hub. A good automotive jobber should get the rear transmission axle seals for you The original 100443 seals are replaced by SKF/Chicago Rawhide 11050 for the 1-1/8" diameter axles. If you have an Ideal Supply or Napa dealer they can get both the bearings and seals for you. Garry Share this post Link to post Share on other sites
953 nut 57,611 #12 Posted March 31, 2015 If you don't have a Toro dealer near you you might wan to try partstree on the internet or vendors here on Redsquare. Share this post Link to post Share on other sites
