motor12 367 #1 Posted March 1, 2015 (edited) The manual calls for (18) 5/16 x 5/8 of an inch long with a lock washer for attaching the side plates to the case. my trans has 5/16 x1/2 inch without the lock washer. What will give me the best results, Thanks Edited March 1, 2015 by motor12 Share this post Link to post Share on other sites
Theroundhousernr 590 #2 Posted March 1, 2015 I usually always follow the manuals. However , I have not cracked open my 5003 yet so cant say either way. I would say as long as they are not to long that they cause problems inside. You would want the most thread in the hole possible because I hear you can over tighten these easily. Since these threads are bottomless, use thread sealant and a lock washer to keep them snug. Share this post Link to post Share on other sites
cleat 6,408 #3 Posted March 1, 2015 I find wheel horse uses a lot of 5/8" long bolts all over but I can usually only find 1/2" or 3/4" bolts. What I have been doing is using 3/4 bolts and adding a flat washer under the lock washer to male up the 1/8" difference. Cleat Share this post Link to post Share on other sites
Jake Kuhn 1,556 #4 Posted March 1, 2015 I use 5/16 x 1/2" and they work fine. In the 30 or so trannys I have owned, I have never seen one with washers. 1 Share this post Link to post Share on other sites
motor12 367 #5 Posted March 1, 2015 I use 5/16 x 1/2" and they work fine. In the 30 or so trannys I have owned, I have never seen one with washers.That's what I wanted to hear, going with the 1/2 and no washers. thanks Share this post Link to post Share on other sites
Racinbob 11,251 #6 Posted March 1, 2015 (edited) It's depending on which parts list you look at. I have one list that shows 1/2" and no washers, another with 5/8" and washers. Either is fine. You need to be careful on the length. It's possible one of them could get into a gear inside. Mine originally had 1/2" and no washers. I replaced them with 5/8" and lock washers but I only did that because I had the 5/8" stainless bolts. Otherwise I would have used the 1/2" I took out. Edited March 1, 2015 by Racinbob Share this post Link to post Share on other sites
