invisybill 1 #1 Posted March 1, 2015 (edited) I saw , Here or some other forum that you can convert to heavy duty spindle and hub kit for the front axle. anyone know where i can find it? Thanks Bill. Edited March 1, 2015 by invisybill Share this post Link to post Share on other sites
KC9KAS 4,744 #2 Posted March 1, 2015 Here is one thread. Do a "search" for spindel upgrade Share this post Link to post Share on other sites
953 nut 57,904 #3 Posted March 28, 2015 You can use utility trailer hubs and bearings and bolt on some 8" trailer tires. You may need to do a little shimming or trimming to make it work. On one of my 953s I did this and it was a direct swap. Share this post Link to post Share on other sites
Kelly 1,030 #4 Posted March 29, 2015 I have a set of factory loader spindles with the correct wheels and like new tie rods, if you want to go factory bolt on, send me a message 1 Share this post Link to post Share on other sites
edgro 679 #5 Posted May 11, 2015 Here is what I did on my C-175 See attached PDF file for pictures and parts list before it was very hard to steer, now it it easy, I put on tri rib tires, they worked well for me snowplowing Hub Upgrade.pdf Share this post Link to post Share on other sites
Tankman 3,520 #6 Posted May 11, 2015 Lots of choices, I've seen hubs on front axles. http://www.mfgsupply.com/gomini/gominihubs.html Share this post Link to post Share on other sites
alswagg 128 #7 Posted May 12, 2015 I put on1" 4 bolt tapered bearing trailer hubs on both of my D's. Very easy swap, The only shim needed was for the Seal to ride on, which is 1 1/4" The rims are standard 4 bolt trailer rims with 5 rib tires. Same size as oem. Good luck Al Share this post Link to post Share on other sites
